Top number Three
Old Nov 23, 2005 | 07:40 PM
WD401958's Avatar
WD401958
Default Top number Three
Well I am fixing to get my third top from G.M.!
I was one of the first ones on here to tell about
the delamination problem. Went to put my top on
this afternoon and saw that it was delaminated at the rear.
The first time it happened it came loose from the front.
This is getting OLD!!!!! If you have gotten your top replaced
you better look at it !
Old Nov 23, 2005 | 07:42 PM
millpond's Avatar
millpond
Have them give you a transparent top next time--it shouldn't delaminate.
Old Nov 23, 2005 | 08:27 PM
Killrwheels@Autogeek's Avatar
0Killrwheels@Autogeek
Former Vendor
my first top was replaced at 1000 miles and two months of ownership. The replacement top has less than 500 miles and one additional month and is creaking and believed to be the same delamination. Contact to Chevy is not forthcoming, and registered formal complaint with the NHTSA .... someone needs to step in and address the issue. Floridas heat and black coloring only seem to speed the delamination process.
And they will not replace top with any other type ... not even with some direction from Chevrolet customer assistance.
Old Nov 23, 2005 | 08:30 PM
Always Red Dave's Avatar
Always Red Dave
What should I be looking for delaminate WHAT? WHERE? THANKS 05 or 06 problem or both?
Old Nov 23, 2005 | 09:19 PM
WD401958's Avatar
WD401958
2005 red
On mine you can lift
the roof panel up off
of the frame assembly at the rear
of roof
Old Nov 23, 2005 | 09:46 PM
2005ArcticWhite's Avatar
2005ArcticWhite
St. Jude Donor '05 thru '11,'18,'20,'21,'24,'25, '26
Old Nov 23, 2005 | 11:08 PM
cerino2000's Avatar
cerino2000
You gotta be fkn kiddin me. Man, if this one starts to peel too I will be really pissed.
Old Nov 24, 2005 | 10:01 AM
mnmvette's Avatar
mnmvette
Has this problem been isolated to a particular build period? No problems yet with mine, built 05/05/05.
Old Nov 24, 2005 | 10:26 AM
NeedaC6's Avatar
NeedaC6
I've had my roof replaced with no further delamination issues....dunno.
Old Nov 24, 2005 | 11:18 AM
WD401958's Avatar
WD401958
I just filled out a formal complaint with the NHTSA reguarding my top.
If anyone else is having the same problem be it the first time or the second,Please register a complaint with the NHTSA. This is the only
way the issue is going to resolved.
Old Nov 24, 2005 | 11:20 AM
WD401958's Avatar
WD401958
To Top number Three
