New C6 transmission problem
Old Dec 3, 2005 | 01:36 PM
puckdoc's Avatar
puckdoc
Cruising
Default New C6 transmission problem
My new C6 A6, with less than a thousand miles, intermittently, at speeds between 25 and 50, seems to forget to shift, revs high then pops into gear with a bang. The Dealer couldn't reproduce it but as soon as I took the car back it did it with a vengeance. Anybody have a similar experience?
Old Dec 3, 2005 | 01:45 PM
TommyV's Avatar
TommyV
St. Jude Donor '06-'07-'08-'09-'10-'11-'12, '16
Nope. There's definitely something wrong.
Old Dec 3, 2005 | 01:55 PM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
Had a problem like this with a different GM car. It turned out to be the TPS. throtle position sensor<spelling>
Old Dec 3, 2005 | 01:56 PM
Jeffjett's Avatar
Jeffjett
1st A6 problem I have heard of. Keep us posted on your progress, and good luck.
Old Dec 3, 2005 | 01:59 PM
StanNH's Avatar
StanNH
Can I be the first to come up with an acronym for this? Oh, please!
Alzheimer Shift Syndrome.
Old Dec 3, 2005 | 02:21 PM
double eagle's Avatar
double eagle
Mine has only 300+ miles, but shifts fine - so far...
Old Dec 3, 2005 | 02:24 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
A whole 300 miles and not a problem.
OK
Old Dec 3, 2005 | 02:26 PM
lovecars's Avatar
lovecars
I had the same thing happen to mine once with about 650 miles in heavy traffic passing Memphis (it did not shift with a bang, though) while driving from the NCM to LA, I called a contact at GM Powertrain that I know and this person told me that it was the trans learning the car. Apparently the A6 has it's own computer in the pan and it learns the way it's driven. It's made this way because this trans will be installed in lots of trucks next year, starting with the large GM SUV's and GM doesn't want to install new computers to handle it, also there are no BIG external wiring harness except for three wires that go to the trans.
Old Dec 3, 2005 | 03:58 PM
Jimbeaux's Avatar
Jimbeaux
The A4 also senses how the car is being driven and adjusts shift points accordingly. Good to know this feature was carried over to the A6 as well.
Old Dec 3, 2005 | 05:53 PM
GTC's Avatar
GTC
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05
Is it going into performance shift mode? It automatically does this when it detects you are doing high speed cornering and rapid accel. It will keep it in a lower gear at higher rpms so you have better get-up-and-go as you exit the corner. Sometimes this is annoying.
Old Dec 3, 2005 | 06:56 PM
puckdoc's Avatar
puckdoc
Cruising
Thanks for the input. I played around with it this afternoon. In the sports mode and paddle shifting its fine but it still occurs in sports mode if I don't paddle shift. The *** (Alzheimer Shift Syndrome) only occurs after the car is warmed up. The effect does seem to be getting worse, however. I'll take it back in on Monday after I drive it around for a while.
Old Dec 3, 2005 | 06:57 PM
archtop's Avatar
archtop
Or could it simply be "Old-timers Shift Syndrome",after all none of us can operate "play station" type games.
Old Dec 3, 2005 | 08:10 PM
prs62's Avatar
prs62
St. Jude Donor '05-'07
Stan, you drinking tonight? LOL
Old Dec 3, 2005 | 08:43 PM
jim213's Avatar
jim213
It's not always fun getting old.
Old Dec 3, 2005 | 10:16 PM
double eagle
OK
Yep, way
Old Dec 3, 2005 | 11:11 PM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
From the get go, I've made it a point to drive in "S" with the TCS in "Comp" mode. Yes, the transmission learns real fast. The more spirited your driving, the better and faster it will shift. 1560 miles in two weeks.
Old Dec 3, 2005 | 11:24 PM
dmeyers's Avatar
dmeyers
Default Big Drum Role for GM
If the A6 has issues the 06 will be a bad year to own. I have not read any A4 issues!!!
To New C6 transmission problem
Old Dec 3, 2005 | 11:49 PM
dark_phantom's Avatar
dark_phantom
From: Central Florida. Black Sheep Squadron Member. 465 rwhp & 477 rwtq
Cruise-In VIII Veteran
St. Jude Donor '07
Let us know how it turn out.
Old Dec 4, 2005 | 12:49 AM
2005ArcticWhite's Avatar
2005ArcticWhite
St. Jude Donor '05 thru '11,'18,'20,'21,'24,'25, '26
Sorry to hear this. Good Luck.
Old Dec 4, 2005 | 06:22 AM
Big Jimm's Avatar
Big Jimm
4600 miles. No problem.
Big Jimm
So. Fla.
