Gas Pump
Old Dec 7, 2005 | 12:26 PM
BKNIMKR's Avatar
BKNIMKR
From: Chino Hills, Ca. You are completely safe with me, I'm a good screamer.
Mine has only popped off prematurely a couple of times, but otherwise, it's been .
martin
Old Dec 7, 2005 | 12:37 PM
vetdude's Avatar
vetdude
If you play with it a little bit before you put it in, it should go in a little easier. If you have to hold it while it's in, that's OK too. Just don't pull it out too soon or you'll have a mess.
Old Dec 7, 2005 | 06:27 PM
ajw22's Avatar
ajw22
St. Jude Donor '06
Mine auto fills fine. I've only done about 5 fills so far though.
Old Dec 7, 2005 | 06:45 PM
ZeusC6's Avatar
ZeusC6
Banned Scam/Spammer
Originally Posted by DoTheyMakeOtherCars?
Uh um...surprise....everyone on the forum is not a guy LOL.
Well then!!!
I guess your the only girl holding someone elses hose?
Just playin' , smile with it!
Old Dec 7, 2005 | 08:29 PM
DoTheyMakeOtherCars?'s Avatar
St. Jude Donor '06
Originally Posted by ZeusC6
Well then!!!
Yes I am , and I am evidently doing a pretty poor job of it
Old Dec 7, 2005 | 09:50 PM
ZeusC6's Avatar
ZeusC6
Banned Scam/Spammer
Thats what she said!!!
I'm too afraid that it'll fall out if I don't hold it. But it has shut off early occasionally, usually I change the angle and then it works fine.
Thats what HE said!
Old Dec 8, 2005 | 12:09 AM
xlr8rvette's Avatar
xlr8rvette
From: Fayetteville Arkansas recently moved from Oakland Ca
St. Jude Donor '06
Mine's a "little hard" too, but its premium !
Old Dec 8, 2005 | 02:22 AM
dbratten's Avatar
dbratten
Mine shut off twice today attempting to fill. Seriously, is it the depth or the rate of fill causing the problem? My sweet C6 was to polite to say which even though she left the station unfullfilled.
Old Dec 8, 2005 | 02:53 AM
C6 ROLLER's Avatar
C6 ROLLER
I don't have that problem BUT when the pump shuts off I can't get an extra few cents in or a squeeze on the handle without overfilling it. Seems to shut off right at max. Anyone else with this problem.
Old Dec 8, 2005 | 07:38 AM
tluck's Avatar
tluck
Works better than any other vehicle I've owned. When the pump clicks off, the tank is full. A lot better than having to trickle in fuel to top off.
Old Dec 8, 2005 | 07:58 AM
SDCEB's Avatar
SDCEB
With the California gas recapture attachment, I find that I have to hold and angle the nozzle into the center, or it will shut off.
Old Dec 8, 2005 | 08:20 AM
Diocles's Avatar
Diocles
When I filled up my C5, I just pushed the tab on the nozzle and let it fill without holding the nozzle. That does not work on my C6, I have to hold the nozzle or it will shut off. Anyone else notice that?
For me it varies at different gas stations.
Old Dec 8, 2005 | 08:39 AM
  #33
VET4LES's Avatar
VET4LES
Same here.
Old Dec 8, 2005 | 02:03 PM
  #34
Forvettes's Avatar
Forvettes
Cruise-In VI Veteran
St. Jude Donor '05-'06-'07
Oh no. Another problem with your C6.
I don't have the problem.
Old Dec 8, 2005 | 02:16 PM
  #35
Boozman's Avatar
Boozman
Mine works fine
Old Dec 8, 2005 | 05:48 PM
  #36
nalto's Avatar
nalto
Same here! Overfilled first fillup coming back from NCM.
When the pump quits, thats all she will take.
Old Dec 8, 2005 | 05:57 PM
  #37
PaBlueCoupe's Avatar
PaBlueCoupe
St. Jude Donor '06-'07-'09
Actually, I've had the premature problem a couple of times. But it is usually just fine.
Old Dec 8, 2005 | 06:53 PM
  #38
aaaaa's Avatar
aaaaa
Default Two hands
I find that using two hands helps.
