Born Date?
Old Dec 10, 2005 | 04:27 PM
mrdcars's Avatar
mrdcars
Default Born Date?
Can anyone tell me my born date or how I can get it. I got a build sheet and it doesn't say as I see it.
I have a 2005 C6 Vert, Vic/red, 6MN, Z51, Last 6 on the VIN are 115711.
Thanks in advance,
Old Dec 10, 2005 | 04:31 PM
crazyeddie's Avatar
crazyeddie
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13
I can get you close. My coupe is 15215 and was born on 01/26/2005.
If you ask whitec5vette nicely he may get you the exact date. He has access to a GM computer that we don't. Good luck--e
Old Dec 10, 2005 | 08:40 PM
Vette_DD's Avatar
Vette_DD
It takes a person who has access to the GM system to look up the exact build day based on the VIN. There's a label on the driver's side door frame that will tell you the month and year.
Old Dec 11, 2005 | 01:10 AM
not08crmanymore's Avatar
not08crmanymore
Default born on
post your vin,somebody will look it up.They need the vin.In the mean time,whatever the sticker says on your door,add 25 days to that and that'll be close to your build date.I.E. mine on door 8/05- actual 8/30.
Old Dec 11, 2005 | 06:02 AM
GCarrHarris's Avatar
GCarrHarris
Look in your wheel well on the right front, directly above the tire. The guys who built your car probably signed it and dated it. I know of quite a few of us who have that. Take a picture of it and post it to see if we have the same builders. Moog and Deo2.
Old Dec 11, 2005 | 07:26 AM
jruss361's Avatar
jruss361
The 8/05 means it was built in August 2005 not the 5th of August.
Old Dec 11, 2005 | 10:09 AM
not08crmanymore
Default The 8/05 means it was built in August 2005 not the 5th of August.
yea,you;re right!The actual build date is in that month,which is what I should have said!Either way,I posted my vin and C5TECH had my info up here in a heartbeat!
Old Dec 11, 2005 | 10:51 AM
Vette_DD's Avatar
Vette_DD
No. No. No. My build date was 11/08/04. The date on the sticker on the door frame says 11/04. Adding 25 days to 04 would be November 29. Once again, the date on the sticker on the door frame has MONTH/YEAR, AND THAT'S ALL IT MEANS.
8/05 means your car was built in August 2005. That's all.
Old Dec 11, 2005 | 10:58 AM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
VIN 1G1YY34U755115711
VEHICLE BUILD
Merchandising Model : 1YY67 -2005 CORVETTE CONVERTIBLE
Gross Vehicle Weight Rating : 1674 kg (3691 lb) Order Number : HSGXT5
Build Date : 02/01/2005 Build Plant : 155Y
OPTION CODES
AAB - MEMORY PACKAGE AJ7 - AIR BAGS, FRONTAL & SIDE IMPACT, DRIVER & PASSENGER
AQ9 - ADJUSTABLE SPORT BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES BGR - BOWLING GREEN PLANT
CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE DD0 - ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR
DD8 - OSRV DL5 - ROADSIDE SERVICE INFORMATION DECAL
FE3 - SPORT SUSPENSION GU6 - REAR AXLE 3.42 RATIO
IL3 - TRIM INTERIOR DESIGN-AQ9 JL5 - CONTROL MANUAL TRANS, 1ST TO 4TH GEAR SKIP SHIFT
J55 - HEAVY DUTY POWER BRAKES KA1 - HEATED SEATS
KNP - TRANSMISSION OIL COOLING SYSTEM KPS - COOLER OIL, ENGINE
K63 - 110 AMP GENERATOR LS2 - 6.0 LITER SFI V8 - 400 HP
MN6 - 6-SPEED MANUAL TRANSMISSION MZ6 - 6 SPD MANUAL TRANSMISSION
NC7 - FEDERAL EMISSIONS OVERRIDE NE1 - 50-STATE EMISSIONS
NK4 - LEATHER WRAPPED STEERING WHEEL NU4 - CAL EMISSION SYSTEM, LEV2 PLUS
N37 - STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN QG7 - POLISHED ALUMINUM WHEELS
R9U - GM ACCESS - AUTOBOOK IDENTIFIER SLM - STOCK ORDERS
UE1 - ONSTAR SYSTEM INCLUDES 1 YR SAFE & SOUND UG1 - HOMELINK TRANSMITTER
UJ9 - LOW TIRE PRESS. INDICATOR URB - AM/FM CD WITH DVD NAVIGATION, BOSE PREMIUM 7 SPEAKER SYSTEM (REPLACES STD/OPT/PKG RADIO)
US3 - ANTENNA DIVERSITY UV6 - HEAD UP DISPLAY
U2K - XM SATELLITE RADIO - OVER 130 CHNLS OF DIGITAL ENTERTAINMENT SERVICE FEE EXTRA.1ST 3MOS.INCL U52 - ELECTRONIC INSTRUMENTATION
U65 - SPEAKER SYSTEM 7, PREMIUM VA5 - ENGLISH LANGUAGE LABEL
VDD - VEHICLE INFORMATION DVD VM3 - CONSUMER INFORMATION LABEL
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA XGN - FRONT TIRE - P245/40ZR18 BW HI-PERFORMANCE
YGJ - REAR TIRE P285/35ZR19 BW PERFORMANCE Z51 - Z51 PERFORMANCE PACKAGE (INCLUDES:LARGER CROSS-DRILLED BRAKE ROTORS,PERFORMANCE-TUNED: TIRES, STABILIZER BARS,SPRINGS, SHOCKS, GEAR RATIOS)
1SB - PREFERRED EQUIPMENT GROUP HEAD UP DISPLAY HOMELINK TRANSMITTER MEMORY PACKAGE AUTO DIMMING ISRV MIRROR W/COMPASS & DRIVER OSRV MIRROR HEATED SEATS RDS AM/FM STEREO W/6-DISC IN DASH CD W/MP3 PLAYBACK, BOSE PREMIUM 7 SPEAKER SYSTEM (REPLACES STD/OPT/PKG RADIO) PWR TELESCOPING STEERING 1SZ - PREFERRED EQUIPMENT SAVINGS
19I - BLACK INTERIOR TRIM 193 - EBONY LEATHER TRIM SEATING
41T - TOP-BLACK 74U - VICTORY RED
Old Dec 11, 2005 | 11:03 AM
not08crmanymore
Default 8/05 means your car was built in August 2005. That's all.
YES,I got it,thanks.
Old Dec 11, 2005 | 11:26 AM
Curtis A. Franz's Avatar
Curtis A. Franz
You are mixing up day and year. the "05" is the year not August 5th. Oops. others have already pointed this out. I wonder if Kevin could look it up for you...ezra.tarrence@gm.com
Old Dec 11, 2005 | 12:47 PM
mrdcars's Avatar
mrdcars
Default Born Date
Thanks to everyone for getting in on this. Hope I didn't cause some of you some heartburn
Old Dec 11, 2005 | 02:22 PM
jazzlove's Avatar
jazzlove
From: San Antonio Texas - Any sufficiently advanced technology is indistinguishable from magic
Gary called me from NCM to let me know when she rolled off the line.
Old Dec 11, 2005 | 03:13 PM
Virile1973's Avatar
Virile1973
[QUOTE=mrdcars]Can anyone tell me my born date or how I can get it. I got a build sheet and it doesn't say as I see it.
Thanks in advance,[/QUOTE
Born date?That sounds so gay.
To Born Date?
