Harmonic Vibration
Old Dec 12, 2005 | 12:34 AM
santsys's Avatar
santsys
Default Harmonic Vibration
Lately i have been noticing a vibration when i drive. At about 45mph it starts, and does not go away. It seems to get a little faster with speed, untll it gets constant and you cant really tell it is happening any more.
It is a cyclic vibration (it's not constant, but it is repeating).
Anyone have any idea what it might be?
I have heard anything from an out of balance Cam shaft to a damaged half shaft.
Anyone have any ideas?
Thanks!!!
(p.s. Car is goin to the shop tomorrow to have it checked out but i like to go in there with a little more information then, hey it's making noise fix it)
--Josh
Old Dec 12, 2005 | 01:12 AM
shopdog's Avatar
shopdog
Thanks!!!
--Josh
Most speed dependent vibrations are wheel/tire or driveline related. In the extremely unlikely case of an engine, or engine accessory, problem, the vibration would be RPM related rather than speed related. In other words, it would show up at different speeds depending on what gear you're in.
Old Dec 12, 2005 | 01:16 AM
Mocoso's Avatar
Mocoso
Old Dec 12, 2005 | 01:23 AM
santsys's Avatar
santsys
Ya, definatly not an RPM thing, becuse i cant feel it untill i get up to speed... I'm really curious to see what it turns out to be.. .Hopefully nothing to major.
If anyone has any other ideas, please feel free to chime in
Thanks Again!
--Josh
Old Dec 12, 2005 | 02:12 AM
Mocoso's Avatar
Mocoso
My first guess would be tires...you didnt mention how long you have had car and/or how many miles on those... does it do this on all types of road surfaces or only a certain type (cement vs asphalt, etc.) Is the sound local to an area in vehicle or does it come from all places?
Stupid question I know but just to rule out the obvious: have ya checked the pressure on the tires?
Let us know what they find out....
Old Dec 12, 2005 | 02:22 AM
santsys's Avatar
santsys
Tires and car have about 1,300 miles on it. it does it on ever road i have driven on so far, freeways (I-5) and side roads... It's not really a sound, it's a vibration, i can here it a little, but i can feel it more than anything. can feel it on the floor and on the clutch pedal when i have my foot touching it...
maybe a tire is out of balance, never thought about that... hmm... intereseting...
Old Dec 12, 2005 | 02:26 AM
purple heart's Avatar
purple heart
You might just try to put the transmission in neutral when the vibration starts just for elimination perposes to see if it stops with the transmission in neutral, whether it be an Auto or 6 speed. Keep us posted if you try this on the way to the dealer's.
good luck
Old Dec 12, 2005 | 08:54 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
I sounds like wheel balance where it's speed and not RPM related.
Old Dec 12, 2005 | 11:50 AM
santsys's Avatar
santsys
good luck
Still has the vibration even when in neutral (clutch in or out). It's at the shop now. Hope they find something (feels wrong saying that, but it's better then having to live with an annoying problem.)
I'll let you all know what they find... if anything... (loose nut behind the Wheel )
--Josh
Old Dec 12, 2005 | 12:42 PM
Crankshaft's Avatar
Crankshaft
St. Jude Donor '08-'09-'10-'11-'12
Tell the dealer to time the footprint on each tire. Watch them go HUH! Amazing what this simple little fix will do.
Old Dec 12, 2005 | 01:50 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Please tell the rest of us about timing the tire footprints...
Old Dec 12, 2005 | 02:37 PM
santsys's Avatar
santsys
Old Dec 12, 2005 | 08:58 PM
santsys's Avatar
santsys
Latest update...
Car is staying overnight, they were able to reproduce the problem. They are going to be swaping wheels/tires to make sure its not that. But they think it is a wheel baring.
I'll let you know what they actually end up replacing.
--Josh
Old Dec 12, 2005 | 09:04 PM
lovecars's Avatar
lovecars
Thanks!!!
--Josh
Sounds like tires and wheels are out of balance... if it ws the motor, the vibration would go away if you put in the clutch or get worse with higher RPM... and frankly if that was the problem the engine would be making noise already.... and if it was that I would run it till it blew up, that way they would not repair it, they would replace it....
Old Dec 12, 2005 | 11:07 PM
purple heart
--Josh
Josh, at least it seems you've eliminated trouble at least with the power train components; chances are it's something else which I would prefer if it was my car, eh? Again, good luck.
Sal
Old Dec 13, 2005 | 01:47 AM
Mocoso's Avatar
Mocoso
Latest update...
--Josh
Well about time they started "baring" those noisy track every rutt run flats .... glad they were able to reproduce and you didnt get the "there aint notin wrong wut here yer car" - do let us know what they replace ...
Old Dec 14, 2005 | 07:45 PM
santsys's Avatar
santsys
Ok, new update...
Well after a few road tests and the use of some special listening device... they have replaced all the tires and wheels, and have concluded that it is nothing that they thought it was. So they have been on the phone with engineers from GM trying to get it figured out... so no clue what is wrong or how long it will take to fix.
yep...
--Josh
To Harmonic Vibration
Old Dec 14, 2005 | 10:51 PM
Jimbeaux's Avatar
Jimbeaux
I had a noisy rear wheel bearing, but no vibration. The dealer replaced the bearing.
Old Dec 14, 2005 | 11:41 PM
lovecars's Avatar
lovecars
Old Dec 14, 2005 | 11:50 PM
santsys's Avatar
santsys
I wish that was what mine was... I never get anythign simple to happen... But hey, at least they are working on it and are not giving me the run around. I am very happy about that.
--Josh
