Yeah. It sounds like the repair has been all over the place in terms of recurrence risk. I love to drive this car but am seriously considering getting rid of it since this is the second time. I was under the impression that it was fixed "correctly" with the diamond edged washer the first time around. What will always lurk in the back of my mind is how long until it happens again? I'd hate to not fully enjoy the car for fear that it might explode. I know that every car has the potential to be a little sour but this one has a a fairly established tarnished record. I wonder if a Lingenfelter package would solve the problem.
I pressed them for a 6 year 72K $0 deductible valueguard extended warranty on my POS. It covers more than just the engine. You can go to the gmpp website and read what all it covers. I don't trust this car one bit. When it runs right, I like it, but it has let me down on many roadtrips. Now the pain is to not mod this car for 6 years.
It does not look that you can trust (or enjoy) the car any longer. I would fix it under warranty and sell it, get the '68 or another C6. Here's the million dollar question: How long has Chevy been building the small block now ? C'mon Mr. Lutz stop spending too much time on the Solstice (the car turned out fine) and fix the LS2 crank pulley issue.
This was never an issue on the LS1/LS6 what is new on the LS2 that would cause this? I'm looking to buy a C6 and have eliminated the 05 from my list because of this.
We, from experience I will tell you that if the pulley bolt fails when you are driving hard it ain't much fun, and could become a life threatening incident.
I meant hard as in not being afraid to apply the power when safe to do so---not as in going around a sweeper on a track at speeds exceeding 100. You and afew others are lucky to escape unhurt from situations that could have been very ugly. But GM tells me mine is fixed and has agreed to warrenty the motor for 100k all the while advertising 400/400---I drive this like it has 400/400. After two failures it turned 12.7/12.8 on it's only trip to the strip---so I gotta believe the motor was not damaged---in fact I am 56 and haven't been to the strip since 1969---if I were a bit younger and more experienced I think I could go lower.
My point in all this is if you get the warrenty as well as being backed up by lemon laws I see no real reason to dump the car at a loss.
and the DBS, and, and, and.
Again this is just not acceptable on the part of GM.
The Corvette is the 'Flagship', but appears to be a sinking one.
My VIN is in the Crank Bolt Pulley range, but with 11,900 + miles, the only problem I've had is the "service active handling". Steering wheel angle sensor replaced at 4800 miles and no probs since then. I'm planning to buy a GM major guard extended warranty for piece of mind and to help resale if need be.
With 9 months and 11k miles I almost traded for an 06 Vert while it was still on the trailer. Even though I only owe $40k, the dealer was going to take my car without trade allowance and sell his at full sticker. Needless to say, I walked.
Nick, hope you get the problem solved for good. I've heard that pinning the bolt is the best real fix. I'd push for that.
My first C6, a Z51 A4, was "fixed" with the diamond impregnated washer. When it failed the 2nd time, the end of the crank was ruined and GM's solution was to replace the engine. Fortunately for me, they had an unexpected problem with the transmission that pushed past the 30 day VA Lemon Law limit. GM was very courteous and bought back that car without any hassle.
I immediately bought another Z51 A4 and even though it's under the crank pulley VIN cutoff, I've had 19K trouble-free miles.
I was about to point this out. I was under the impression that once they fixed it, if it failed again with the diamond washer in place, you'd have to replace the engine because the washer would eat the end of the crank. Be careful and make them do it right!
I had a Corvette shop that was going to do the pin job( just cause I was worried) for 250.00.I still haven't done it but was told that is the absolute sure fire fix.Dave at Cartek told me that if the bolt was torqued properly you shouldn't have a problem.He told me he's had an underdrive pulley on his heavily modded car which was pinned and drag raced with it regularly.Now he has returned the engine to stock ( cams etc) and twin turbo'd it put the original balancer back on with the same bolt ( no pinning) and run's 10's at the track.If the job is done right you don't have it fall off.Yours may have had damage to the crank the first time which is why the fix failed.Thats the real danger of this problem. If it beats up the crank snout the fit could be wrong and the fix won't work but they're supposed to check .
