Checking Tranny Fluid
Is this on the level?
John
John
The point is, it is filled from the factory. Therefore, if there are no leaks, there is no need to check it (in theory anyway).
I can replace my tranny fluid if I try, but that's not why I bought a Corvette.
Sound familiar? kinda sucks when your post is on the receiving end isnt it.....
John
I assume you're talking about the manual transmission.
For a manual, there's a plug on the side, fluid should be up to the plug. Lift the car, remove the fill plug (the upper one!), and stick a pipe cleaner or something like that in to check the level. Don't be surprised if a little bit dribbles out when you remove the plug.
If you need to add any, a fluid pump that fits into the ATF bottle ($5-10 from an auto parts store) helps.
It probably doesn't need changing, but some do it anyway. I changed mine at 3K miles, the fluid in there looked like new so I probably wasted my time. But the differential lube wasn't nearly as clean, so if you're going to get your hands dirty, you might want to consider changing that.
The manaul transmission uses ATF (automatic transmission fluid), some folks have changed to Royal Purple Synchromax and report better shifting (search for threads on this) .
The engine must be running and the transmission up to operating temperature when checking. Apply the brakes and run through each gear, then back to Park. Next, release the foot brake, apply the parking brake, and with the engine still running... check the fluid by pulling the fill plug on the side of the case. If the fluid is at the bottom of the fill hole threads or gently dribbles out, your tranny is full. If you pull the plug on a full transmission with the engine off, fluid will gush out.
By the way, did you notice any improvement in shifting from the RP? I used Mobil 1 ATF, it might make a little difference but only a very little. I'm thinking about trying the Synchromax when I get a chance to get back under the car.
I changed it a while ago but I remember that I did feel a small improvement. That may have been a placebo effect; maybe since I went to the trouble of changing the fluid, I willed myself to feel a difference.
