Motor Trend - C6 Powertrain - Variable Displacement?
Old Aug 2, 2001 | 10:32 PM
CDHough's Avatar
CDHough
Cruise-In II Veteran
Default Motor Trend - C6 Powertrain - Variable Displacement?
In the new Motor Trend (September) there is an article about the 2004 Camaro. Here is the quote (pg 81):
"Expect the current powertrain relationship with the Corvette to continue, with the C6 passing along its Gen IV small-block pushrod V-8 evolved from the current Gen III LS1/LS6 V-8s, with such advances as an 8-6-4 variable-displacement cutoff system and drive-by-wire throttle."
- Charley
Old Aug 3, 2001 | 04:09 PM
carpe dm's Avatar
carpe dm
Default Re: Motor Trend - C6 Powertrain - Variable Displacement? (CDHough)
I think this is a possibility; I know they have been giving this some serious thought...... :boxing
Old Aug 3, 2001 | 04:35 PM
ShanMan14's Avatar
ShanMan14
Cruise-In V Veteran
Default Re: Motor Trend - C6 Powertrain - Variable Displacement? (carpe dm)
It's clearly under (re)development. I've read in many publications GM wants to bring this back. Let's just hope the new version works!
Old Aug 7, 2001 | 12:31 AM
Y-Body's Avatar
Y-Body
From: Member since May 99 (Before 99 CF Crash & Burn) Georgia
There are indications that some GM truck V8's will have DOD in 2004. Not 8-6-4 but 8-4.
Old Aug 7, 2001 | 10:56 AM
black97magic's Avatar
black97magic
Mercedes is doing this in their cars. The technology has caught up to this concept. They say that the Mercedes is seamless and you don't even realize it's taking place. It is a definite possibility :D
Old Aug 8, 2001 | 07:19 PM
Mike Mercury's Avatar
Mike Mercury
Default Re: Motor Trend - C6 Powertrain - Variable Displacement? (black97magic)
With the ill-fated V8-6-4, the main prob was in the 6cyl mode. The active cylinders did not fire evenly. The General knows better now and the new DOD engines are to be V8-4 (at least if you believe what is currently in print).
Old Aug 10, 2001 | 11:11 PM
Corvette ED's Avatar
Corvette ED
From: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Default Re: Motor Trend - C6 Powertrain - Variable Displacement? (Mike Mercury)
That would be a good reason NOT to buy a Corvette. :chevy :chevy :chevy
Old Aug 12, 2001 | 10:05 AM
MagRed_04's Avatar
MagRed_04
I know that they are working on the 8-6-4 concept for the big block truck engines... I haven't heard for sure about the small block though... The engineers tell me that the system is much better than the old electrical system the cadillac used... I guess this one is all run by hydraulics.
Old Aug 12, 2001 | 01:17 PM
ChrisTinaBruce's Avatar
ChrisTinaBruce
What would be the purpose of put in a 8-4 engine in such a low production car like the vet? Will the Cad only have this engine? You know the bean counters.
To Motor Trend - C6 Powertrain - Variable Displacement?
