I can host them and planned to store them on my website once my CDs arrive Tuesday. If someone wants to email me (abrimberry at wall dot com) the ISOs of the CDs, I'll post them today. Thanks.
Has anyone sent you the ISO files? Please post when you have them available...TIA...BoB
Had my update done yesterday and watched the process at my local dealership. Pretty simple to do and the TechII showed no codes after the update so I was in and out in under an hour
My paperwork has it listed under warranty repair N/C.
Originally Posted by Corvette Junkie
My upgrade disks came yesterday. I finally got the nerve to try the install today. All went smoothly. After the install I got and MP3 disk that I burned last year to try with no luck. When I put it in today the screen came up saying loading disk. Then shortly it began to play. My C6 was built mid-December 04 VIN 11987.
Did anyone who had theirs upgraded lose their saved memory points? Thanks.
I just tried an MP3 disk in our new 05 C6. It played just fine, does anyone know if this means that I do not need the update disk?
You must have a very late VIN 05. I believe the later models received the same nav unit as the 2006's. As long as you do not have the static problem I would not worry about it.
The Tech II is the service scanner used by dealers, $5200 retail (about half that if you know where to look). Among other things, it reads and clears DTC (Diagnostic Trouble Codes), from the various computerized systems on the car.
So do you have to have this Tech II scanner to do the upgrade or not???
Right Click Link, Select "Save Target As..." ~10MB Download
Unzip archive
Write the 2 ISO images to 2 CDs
Follow instructions in the text file
If you don't know how to write ISO images to CD, search google.com. You will need a program that can convert and write an ISO image to CD.
Performed upgrade on VIN 101586 (Sept. 2004). See picture below.
Click thumbnail to view larger image:
Used your download and text files, it worked great! Thanks.
