It's all torque...or is it?
Originally Posted by c6vette
Keep it simple--- Horsepower is how fast you can get to the wall--Torque is how much of the wall you take with you. Or --HP is voltage-Torque is the amps!
A Volt is a unit of electromotive force so is roughly equivilant to torque, while Amps are flow quantity and more equivilant to RPM.
Originally Posted by xs650
Nope, Hp is equivilant to Watts, 1 HP = 746 Watts.
Originally Posted by tom4416
Not true, horsepower without torque is worthless. Drive a Honda S2000 to see the principle at work. It's a 240HP lightweight sports car but is a dog until you rev the engine into the torque range. Both measurements are important to acceleration and where they occur on the curve is equally critical as to how driveable the car is. Suffice it to say the C6 has plenty of both and they are programmed in at the right points (of course, more is always better!).
After reading all of these post I think I have it. When my wife and I go grocery shopping I should shift at around 6000 RPM and keep the rev's above 4500 at all times. That will make the trip a lot more fun.
Contrary to Car & Driver's frequent misuse of the term "horsepressure", there's also a water analogy. RPM = water pressure in psi, torque is equivalent to the pipe size, and horsepower = flow-rate, like gallons per minute.
Originally Posted by purple heart
This, too, may sound weak but I too have an A4 '05 and I like to use the shifter as if it were a stick shift so, my question is what are the maximum shift points for an automatic, 2005 A4? Or, is it so simple that with an A4 you just shift at the redline?
Originally Posted by Irv
I'm sorry, but this analogy is incorrect. RPM is analogous to voltage, torque is analogous to amps, and horsepower is defined by physics as being convertible to watts, at ~746 watts/hp.
with voltage and current. As someone who works with
electrons for a living, I can tell you the comparisons
between HP, amps, voltage, water pressure, and RPM
make absolutely no sense whatever. It's confusing
but, worse, it's incorrect.
Pat
Originally Posted by exukboy
I have a question re torque. If the LS2 motor makes maximum torque at around 4,500 rpm's, if one was say driving their C6 through the gears as fast as possible, what's the point in taking the motor up to around 6,000 rpm's where torque has already significantly dropped off. Wouldn't the car reach it's speed quicker if one were to shift through all the gears at 4,500 rpm's ? It's probably a dumb question but I was looking at the LS2 HP/RPM graph kindly posted by forum members and I can't fathom it out.
question is here:
http://www.vettenet.org/torquehp.html
Pat
Yeah, that's the ticket, I'm sure your wife will really appreciate it. At least that's one way to get out of having to go grocery shopping!
Originally Posted by catpat8000
You guys need to draw the line at making analogies
Pat
Pat
#33
You LAUNCH at peak torque (make chassis mods as necessary for traction) and SHIFT at peak HP. Proper gearing keeps the engine in the powerband between shifts. I drag race ATVs and they are very sensitive to minor changes, everything is amplified in a 3lb/HP chassis.
#34
Originally Posted by Velocity Steve
If you had a car with a continuously variable transmission, your best acceleration would be acheived by running the engine at maximum horsepower, not maximum torque.
That is absolutely correct except for the launch, torque gets the chassis moving.
#35
Excuse me? It's frightening to think you work with electrons for a living and don't know that 1hp = 746 watts. That part is not really an analogy, that is a fact. Since horsepower can be calculated from torque and rpm, or from volts and current, these transformations are not incorrect, they are commonly taught in high school physics.
and didn't know about HP and watts, you might wonder. But
that wasn't what I was trying (admittedly poorly) to say.
To be clearer, I had two main points:
1. For someone trying to understand HP and torque, the
electrical power/voltage/current analogy is, in my opinion,
unenlightening and does not advance their
understanding significantly. It might be a useful analogy
to someone who does understand electrical engineering
but isn't a car nut but that's probably not the majority of
posters on this forum.
2. The post near the top of this page, to which I thought
I had responded, but after re-reading see that I didn't,
claimed that current was analogous to rpm, which I claim
is erroneous. I now see I responded to your posting which
also made the same point I am trying to make. Sorry for
the confusion - I read your posting too quickly.
Pat
#36
I can tell you that's exactly what they do. You launch,
there's an initial period where the engine climbs up to
the max HP rpm, near the top of what would normally be
a first gear, and then it stays at the max HP rpm while
the car accelerates.
It's actually very weird driving such a vehicle. You keep waiting
for a shift which never comes...
Pat
P.S. The two vehicles were an Audi A4 and a Nissan Murano.
#37
Absolutely. And having driven two vehicles with CVTs,
Pat
Pat
#39
Originally Posted by orca1946
WOW !! Just be happy that you have both!
CVT cars. If so, I don't own either one. Both drives
I referred to were in friend's cars. I only own a C6.
Pat
#40
