Quick question re: Jacking points...
Old Dec 26, 2005 | 08:58 PM
exukboy's Avatar
exukboy
Default Quick question re: Jacking points...
I've just jacked up my C6 using the jacking points located at each corner of the frame perimeter. My jack has a pad that is slightly larger than the oval ressed cut out and when jacking at these point, the surrounding metal (not the body plastic) bent up slightly. If I had used those nylon jacking pucks it would not have happened. Anyway is it a big deal that the surrounding metal flattened (bent up) a tad or does it not matter in the least. I hate to think I'm damaging my vert with just 1k miles on the clock! Anybody else had this happen? I would have thought that it was ok to jack anywhere as long as it's below those jacking points even if it does include the surrounding metal by 1/8th of an inch or so?
Old Dec 26, 2005 | 09:38 PM
cmb13's Avatar
cmb13
Probably no big deal if not noticible and no cracks. Post some pics. Then check out the pucks from Elite Engineering. Beautiful - good garage decoration even if you don't use them!
Old Dec 26, 2005 | 09:56 PM
tom4416's Avatar
tom4416
Doubtful it did anything beyond cosmetic damage although I'd still look for any cracking. The owners manual does not say to jack from those points, it uses crossmember points for jacking although I've yet to find a jack that would fit under to those points. Using the rail jacking points is for a four point lift. To use those points, you need the jacking pucks or old hockey pucks to not damage the car.
Old Dec 26, 2005 | 10:21 PM
VA-Vette's Avatar
VA-Vette
I keep a set of the the Elite Engineering pucks in one of the rear storage compartments just in case I need to jack up the car. They work great and like CMB13 says, they look great! http://www.eliteengineeringusa.com/C6jacking-pads.html
Old Dec 26, 2005 | 11:40 PM
exukboy's Avatar
exukboy
Thanks for the advice and the Elite Engineering jacking pucks look great quality. So it would seem to be ok to lift the car at these points even when using a puck without twisting the frame or doing any other kind of damage just to say remove a wheel etc I guess?
Old Dec 27, 2005 | 02:26 AM
ufso's Avatar
ufso
Use The Search Button
Old Dec 27, 2005 | 06:24 AM
cmb13's Avatar
cmb13
I personally jack from the front or rear, and use those places with the pucks for my jack stands. I don't like the twisting that occurs when jacking from the pucks.
Check out bugman's website:
Old Dec 27, 2005 | 08:45 AM
Dave S's Avatar
Dave S
Retired & lovin' it!
HOCKEY PUCK....no joke....stop in any local sporting goods store & pick up a couple of hockey pucks...99 cents each! They don't have the extension to insert into the frame rail slot, but it's no big deal to center the puck under the frame rail jacking point as you raise your floor jack. They work & they're CHEAP!
Old Dec 28, 2005 | 08:39 PM
VETTE-NV's Avatar
VETTE-NV
16 Vettes and counting…..
Can you jack up a C6 with the doors closed, or do they have to be unlatched?
Old Dec 28, 2005 | 08:57 PM
AFTERBURN's Avatar
AFTERBURN
I jack from front and rear. Pucks are for my jack stands.
Old Dec 28, 2005 | 09:26 PM
orca1946's Avatar
orca1946
I got plastic inserts form mid america that fit into the holes & stay there so if need be you are ready.
Old Dec 28, 2005 | 11:20 PM
exukboy's Avatar
exukboy
I don't think it makes a difference cos the car has a perimeter frame.
I opened the drivers door when mine was jacked up at the front rail and noticed no binding with the door latch at all.
Old Dec 28, 2005 | 11:58 PM
VETTE-NV's Avatar
VETTE-NV
Cool...thanks!
Old Jan 1, 2006 | 04:46 PM
Griff2002's Avatar
Griff2002
Can anyone suggest a good jack to buy. I've heard some have the low clearance needed.
Old Jan 1, 2006 | 06:17 PM
VETTE-NV's Avatar
VETTE-NV
I just bought one of these on ebay.
http://cgi.ebay.com/ebaymotors/Alumi...QQcmdZViewItem
Old Jan 1, 2006 | 06:24 PM
K9-JUSTICE's Avatar
K9-JUSTICE
Have you taken delivery and used the Jack you order off of Ebay? Thats a really nice Jack. Let us know how well it works jacking the car from the front.
Old Jan 1, 2006 | 06:42 PM
VETTE-NV's Avatar
VETTE-NV
NO....I just bought it yesterday.
To Quick question re: Jacking points...
Old Jan 3, 2006 | 09:47 PM
Griff2002's Avatar
Griff2002
I just ended up buying one at Northern Tool Works located near where I live. It looks very similar to the Ebay one, but is a different brand name.
Old Jan 3, 2006 | 10:02 PM
Bob06COUPE's Avatar
Bob06COUPE
if it will make you sleep better....my four frame points already looked a little tweaked right from the factory...i thought that i caused the minor damage till i looked the other points that i didn't use...they all looked the same...strange
Old Jan 3, 2006 | 10:22 PM
TommyV's Avatar
TommyV
St. Jude Donor '06-'07-'08-'09-'10-'11-'12, '16
