C6 headlight adjust
Old Dec 30, 2005 | 09:09 PM
z51dcs's Avatar
z51dcs
Default C6 headlight adjust
Low beams on the C6 have a very flat top. Mine came from the factory with the driver side beam lower than the passenger side to the extent that it bothers me. I would like to raise the driver beam a little to level them up. Nothing in the manual about adjustment. I noticed three holes under the hood on each side near the lights. One hole on each side has what appears to be a torx screw adjustment. Anyone out there with any knowledge? Thanks.
Old Dec 30, 2005 | 10:41 PM
Crush1's Avatar
Crush1
The xenon lights have built in masks to protect the eyes of cars coming at you. The mask creates the sharp break line between bright light and darkness. I found it unnerving when I first experience them because beyond that sharp cutoff line it is pitch black which leaves you feeling insecure about what is ahead. It is really bad when making left hand turns. They intentionally have the left side masked lower to help reduce the impact to oncoming drivers. The masks are absolutely necessary to avoid blinding oncoming traffic. If you notice, when a car with these blue xenons is coming at you and it goes over a high roll in the road, such as a railroad track crossing, you will feel the intense brightness of the unmasked light when that car crests the high point. I am not convinced these ultra bright lights are the best thing, safety wise. What good does it do to have this nuclear-blast light intensity if you need a mask that cuts off all light beyond some relatively short distance? I am not convinced this is progress.
Old Dec 30, 2005 | 10:55 PM
Vet's Avatar
Vet
Originally Posted by rkk
The xenon lights have built in masks to protect the eyes of cars coming at you. The mask creates the sharp break line between bright light and darkness...
Is this "mask" adjustable? Or is the bulb adjustable within the mask? In other words, can that break line between light and darkness be adjusted at all?
I have also noticed this "break line" and wish it was a bit higher. I've been using my high beams a lot to compensate, but it does get annoying to constantly have to turn the high beams off and on each time an oncoming car approaches.
Old Dec 30, 2005 | 10:59 PM
C-INRED's Avatar
C-INRED
St. Jude Donor '06
I've had these on other vehicles also and none have been all that good IMO. I have self leveling lights on my other car (an SUV) which help the oncoming drivers but not me, unfortunately. Since the SUV sits higher, it is even worse with the cutoff because the lights are projected at a greater angle onto the pavement.
Old Dec 31, 2005 | 12:03 AM
double eagle's Avatar
double eagle
Would like to see GM adopt the self-adjusting design currently offered as an option on BMWs - also follows curves.
Old Dec 31, 2005 | 12:22 AM
C7Z51's Avatar
C7Z51
From: Never take a girl out for a cup of coffee, the last thing you want her to be is alert and focused. Tampa, FL
St. Jude Donor '05
I have self leveling HID lights on the Lexus IS300, you can see the lights move down and up at start up. I for one cannot live without HID lights. I feel like i'm driving without any headlights on in any other cars without HID.
Old Dec 31, 2005 | 05:11 AM
shopdog's Avatar
shopdog
That's the vertical adjustment (there is no horizontal adjustment). On a flat level surface, set the car exactly 25 feet from a wall. Mark a horizontal line on the wall the same height as the HID capsule. Turn on the lights and adjust the screw until the very top of the bright zone touches the line you just made.
Old Dec 31, 2005 | 05:24 AM
jkonkle's Avatar
jkonkle
Go big or don't go...
I agree with this - I found the backside of HomeDepot to work quite well. Walmart is always busy on all sides. Wakes good use of a rather large wall! It also gave me a good idea of how WIDE the band ran.
Be careful not to set these tooooo high or all drivers are very unforgiving!
JK
Old Dec 31, 2005 | 07:37 AM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Thanks.
Old Dec 31, 2005 | 08:34 AM
Top Flight Reproductions's Avatar
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15
I agree. My wife's BMW has this feature and it works very well.
Old Dec 31, 2005 | 08:41 AM
888usa's Avatar
888usa
I have a C6 euro spec in England & they all come with self adjusting HID lights with headlamp washers build in the front as standard spec.
Mind you we do pay twice the price for a vette in the UK
Old Dec 31, 2005 | 09:46 AM
webdzynes's Avatar
webdzynes
What makes them "self-adjusting (and could this a new after-market option we havent jumped on yet)? I like the idea....
Old Dec 31, 2005 | 10:19 AM
Dale_K's Avatar
Dale_K
I've had HIDs on 2 other cars and they both came with a dashboard **** to set the low beam elevation. It ran an electric adjustment motor. Some other cars have self leveling lights. I thought one method or the other was mandatory with HIDs due to federal regulations. Maybe since Corvettes don't have back seats or trunks its not possible to load them down enough to inadvertently raise the beams. Anybody know the real deal?
Old Dec 31, 2005 | 10:37 AM
TommyV's Avatar
TommyV
St. Jude Donor '06-'07-'08-'09-'10-'11-'12, '16
My left high beam is too high. Can you adjust that also?
Old Dec 31, 2005 | 01:03 PM
jkonkle's Avatar
jkonkle
yes, approach the vette from the side of the fender with the hood up; lean over and look into the inside of the fender (engine compartment). There should be a deep hole with an adjustment (silver). You'll need an allen wrench; metric but I can't remember the size at this time.
One on the passenger side as well!
JK
Old Dec 31, 2005 | 01:12 PM
C-INRED's Avatar
C-INRED
St. Jude Donor '06
The self-leveling lights (not on Vette) are just what the name implies. If you're going uphill they adjust downward and if you're going downhill they adjust upward. This feature is meant to keep the lights out of the eyes of oncoming drivers (when the vehicle is going uphill) and give you better visibility when you're going downhill. It really helps the oncoming drivers and keeps them from flashing you all the time. I believe self-leveling headlights are mandatory in most European countries and in Canada.
Old Dec 31, 2005 | 01:17 PM
2005ArcticWhite's Avatar
2005ArcticWhite
St. Jude Donor '05 thru '11,'18,'20,'21,'24,'25, '26
Very good info.
To C6 headlight adjust
Old Dec 31, 2005 | 02:09 PM
TommyV's Avatar
TommyV
Thanks Joshua.
Old Jan 1, 2006 | 03:35 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
I thought that self-leveling headlights compensate for changes in vehicle loading that raise or lower the front of the car, thus raise or lower the headlight beam. Wasn't aware that they can compensate for terrain. Can anyone else give the definitive word on this?
Old Jan 1, 2006 | 03:57 PM
xs650's Avatar
xs650
I think you're right. The other way doesn't make sense
If it were how they worked, low beams wouldn't even tough the road surface going down a steep grade and would cut off less than 30 feet from the car going up a steep grade. On a few hills in San Frran cisco, they would cut off at about 10 feet going up hill.
