dash input beep volume
Old Dec 30, 2005 | 10:00 PM
bradb's Avatar
bradb
St. Jude Donor '06-'07
Default dash input beep volume
Sorry if this has been discussed, but I couldn't find it in the FAQ...
Is there any way to set, delete or control the volume level of the beep that happens when you press a DIC gauge button. When I'm cruising along and check tire pressures or switch from fuel level to whatever, that damn beep is loud as hell.
Grazie,
Brad
Old Dec 30, 2005 | 10:53 PM
Vette_DD's Avatar
Vette_DD
Not on the 2005 model. Not sure about the 2006 model.
Old Dec 31, 2005 | 12:00 AM
double eagle's Avatar
double eagle
Originally Posted by SilverCoupe
... Not sure about the 2006 model.
I'd like to know as well, because it is truly annoying.
Old Dec 31, 2005 | 12:37 AM
calemasters's Avatar
calemasters
Grazie,
Brad
Try this: (assuming you do not have the Nav radio)
To change the volume level, press and hold push-button 6 with the ignition on and the radio power off. The chime volume level will change from the 'normal' level to 'loud', and "Loud Chime Vol" will appear on the display. To change back to the default or 'normal' setting, press and hold push-button 6 again. The chime level will change from the 'Loud Chime Level' to 'normal', and 'normal Chime Level' will appear on the display. Each time the chime volume is changed, three chimes will sound as an example of the new volume selected.
Note: There currently is no option available to adjust the chime on vehicles equipped with a Navigation radio.
Old Dec 31, 2005 | 01:43 AM
bradb's Avatar
bradb
Calemasters... thanks. I'll give that a shot tomorrow morning.
best regards,
Brad
Old Dec 31, 2005 | 09:15 AM
Vette_DD's Avatar
Vette_DD
Page 3-101 of the 2006 owner's manual for the above information. This option is not available on the 2005 C6. Bradb's profile says he has a 2005 C6. Sorry bradb, this will not work for your car, as I told you in my earlier post.
Old Dec 31, 2005 | 10:01 AM
UberR32's Avatar
UberR32
Default Wrong
I have an 05 and it does work. However, "normal" is still loud enough to make me deaf. Evidence that the vette is targeted to people much older than I am.
Old Dec 31, 2005 | 10:07 AM
Vette_DD's Avatar
Vette_DD
Or targeted to people with loud exhausts. How many threads have you seen in this section where C6 owners changed their exhaust to make it louder?
If this chime level change does work on your 05 C6, it must be something that started in mid-year, since it's not in the owner's manual.
bradb's Avatar
bradb
I just tried the settings from calemasters and it did work. Still too effing loud, though, I agree. Is that the speaker on the driver's side A pillar? If so, I might take it off and add some muffling to it.
Happy New Year, folks!
Brad
Old Dec 31, 2005 | 10:12 AM
Vette_DD's Avatar
Vette_DD
Brad
No, that's the microphone for the OnStar, and maybe the Nav too.
Old Dec 31, 2005 | 10:47 AM
double eagle
That bites.
Old Dec 31, 2005 | 10:50 AM
JmpnJckFlsh's Avatar
JmpnJckFlsh
Say Again?
Actually, doesn't matter if he can adjust it or not...Radio only has two chime volume levels...VERY LOUD (DEAFENING) and BEYOND DEAFENING.
Old Dec 31, 2005 | 12:01 PM
sanspeur's Avatar
sanspeur
Default Not in manual doesn't mean not in car.
This wouldn't be the first time that something is not in the manual but is on the car. My '05 C6 was manufactured in Oct. '04, and there was no information in the manual about how to change from "military" time to conventional (am/pm) time on the clock. I had to get the info from GM, and then they sent me the wrong info. I think it was someone on the forum who finally gave me the correct instructions.
Old Dec 31, 2005 | 02:51 PM
2005ArcticWhite's Avatar
2005ArcticWhite
St. Jude Donor '05 thru '11,'18,'20,'21,'24,'25, '26
Old Dec 31, 2005 | 04:06 PM
Hoonose's Avatar
Hoonose
Well dayem!
Lern sumthin new everday!
Old Dec 31, 2005 | 05:01 PM
Vet's Avatar
Vet
I have very sensitive ears and am extremely sensitive to loud and/or annoying frequency sound. Ironically, I do not find the "beep" to be so bad. It's loud, yes, but not THAT loud. I wish the beep wasn't there, but at the same time, it doesn't bother me too much.
If anything, the beep is specifically annoying when your passenger is talking to you and you wish to quickly check your DIC gauge info... then your passenger is interrupted by the beep noise... they tend to not appreciate that.
To dash input beep volume
