Had this made from Forum vendors Exoticvette.com & THE C6 Rear emblem is from PFYC.
The partition does a couple of things. Its keeps your stuff in the rear hatch area concealed, pushes rear speaker sound forward, keeps things from flying forward in a quick stop & gives a good place for cd cases, water bottles, quick shopping items.
For new C6 coupe owners, you may not of seen the Petition yet so here it is
Guitarstar: How did you get the emblem to adhere to the carpet? I received my partition just before Christmas but haven't put it in yet. I have an emblem currently mounted on the exhaust plate bracket (that I can no longer use because I installed a Borla exhaust system). I think that a little heat on the back of the plate will allow me to remove it but then I will need to determine how to mount it to the partition. I'm thinking that I can use the 3M tape or a couple other types of adhesives. Do I have to give the area of the carpet where the emblem will be mounted a "hair cut" first? Depending on what you tell me I may just buy a new emblem.
This is a "rear" emblem. It came with a tape adhesive. I had to cut off two metal studs with wire cutters that were sticking out for rear mounting.
You do not need to give the petition a haircut. I peeled the backing paper off after I snapped off the metal studs & it stuck right to the petition. I would recommend a 3M spray adhesive or two sided heavy-duty "Thin" tape.
