Door alignment problem...
Old Jan 2, 2006 | 11:35 AM
LagunaC7's Avatar
LagunaC7
Default Door alignment problem...
I noticed that my driver's door was a little more difficult to close than passenger's door and upon further inspection, I found the the door latch is not aligned with the latch perfectly and thus rubbing on the lower portion of the latch opening. See pics. Is the door out of alignment or the latch? Any idea on how to correct this?
Old Jan 2, 2006 | 11:39 AM
Ucraz-E's Avatar
Ucraz-E
I would take it to your dealer and have them align the door. No sense messing with it while it's under warranty.
Old Jan 2, 2006 | 01:45 PM
double eagle's Avatar
double eagle
Old Jan 2, 2006 | 01:48 PM
achilds's Avatar
achilds
Yup, go see the dealer.
Old Jan 2, 2006 | 03:47 PM
LagunaC7's Avatar
LagunaC7
Will do, thanks fellas!
Old Jan 2, 2006 | 08:47 PM
tommy1727's Avatar
tommy1727
OK, first get a really big hammer...just kidding! I can tell the striker is draging on the latch from your pics. You can adjust the striker by loosening same and repositioning it a little higher than it currently is. If I remember correctly it is a T40 torx head. However, a quality body tech (presumably at the dealer???) should be able to adjust the stiker in a couple of minutes. This type of problem is minor but should have never gotten out of the plant!
Old Jan 2, 2006 | 08:52 PM
tommy1727's Avatar
tommy1727
I almost forgot, the striker might need to be shimmed out from its current position as well as raised. GM has a part number for the shims or a body shop should have them laying around.
To Door alignment problem...
