big problem with my c6 ?
it all seems to have started when a valet left my car in 1st for two days. they had to jump start it to get it running.
i didnt notice anything right away, it would start up fine and drove great.
a day later my right front blinker did not work, the car sat for a week after that.
then it was a little hard to start, and when i would open the door the window will drop down two inches then stop.
and when i got in the car it said no fob detected
and when i tried to start it the battery was dead and when i jumped started it the "service column lock" came on.
the diagnostic center on the car says i have 0 tire psi in three of the tires
any body know what is wrong with this car?
I am no expert but I would be inclined to think that in the process of jump starting the car there was a surge in the electrical system that may have damaged one or more of the numerous processors located in your C6.
That is only a guess on my part, I would have a complete diagnostic done to check for any damage.
Good Luck!
Good Luck!
You have a simple case of dead battery syndrome. Put a charger on your battery for a few hours and you'll be back in business. After you're up and running again you'll need to reset your windows for indexing. (Instructions are in your owner's manual.)
I had similar problems, see post #42 in the following thread
http://forums.corvetteforum.com/show...&highlight=dbs
