Crank Pulley Problem Update
Old Jan 3, 2006 | 05:04 PM
HOTSOSS's Avatar
HOTSOSS
Default Crank Pulley Problem Update
This is an update on the ASSUMED crank pulley problem with the 2006 vert that arrived at the dealer with a problem that caused the belt to fray immediately. Another forum member contacted the dealer and found out the problem was with the idler pulley and not the crank pulley as I had assumed. However the factory has been notified about the problem and asked to review the install process for the idler pulley. Hopefully the crank pulley problem is behind us for 2006 and beyond. I appoligize for assuming the problem was something else.
Old Jan 3, 2006 | 05:08 PM
b4i4getit's Avatar
b4i4getit
If the idler pulley is destroying belts this is still a concern. A missing belt will leave you stranded no matter how it happens.
Old Jan 3, 2006 | 05:15 PM
Vet's Avatar
Vet
I would hope and expect the idler pulley to be easier to repair than reinstalling a crank pulley / balancer (which requires fairly major disassembly of the front of the car). I think I'd rather have a loose or failed idler pulley than a thrown harmonic balancer.
Old Jan 3, 2006 | 05:27 PM
Nort's Avatar
Nort
Old Jan 3, 2006 | 06:17 PM
VNAMVET's Avatar
VNAMVET
Veteran: Marine Corps
...............loose crank pully bolt, idler pully malfunction..........don't care.............these are stupid problems that should not happen to any car, much less one that costs $50k............
My crank bolt issue (2005 A4 Coupe, built 11/04) happened at 2,000 miles.....unscrewed itself completely from the crankshaft...........
Old Jan 3, 2006 | 10:02 PM
double eagle's Avatar
double eagle
- not to mention possible damage inside the engine compartment. Folks, this isn't rocket science here - it's a quality control issue.
Old Jan 3, 2006 | 10:52 PM
JSMDMD's Avatar
JSMDMD
Default Hmmmm.......
Old Jan 3, 2006 | 11:12 PM
LS1LT1's Avatar
LS1LT1
Glad to hear it's not the pulley.
Old Jan 4, 2006 | 12:34 AM
Another Yellow's Avatar
Another Yellow
St. Jude '03-'04-'05-'06
Originally Posted by double eagle
..... it's a quality control issue.
It's one car.
To Crank Pulley Problem Update
