Acceleration A4 VS A6
Old Jan 11, 2006 | 02:50 AM
  #61
fdxpilot's Avatar
fdxpilot
Originally Posted by LS1LT1
Even 3.42s might render that first gear useless...3.15s or even only 2.73s might be the ones.
A set of take-off 2.73s from an A4 might be just the ticket.
Old Jan 11, 2006 | 02:54 AM
  #62
LS1LT1's Avatar
LS1LT1
And the best part is those old 2.73s were virtually WORTHLESS and plentiful once removed/replaced on C5s/C6s, people couldn't even give them away so they might be readily available.
Only problem is the 2006 rear has been upgraded/updated as well so there could be fitment issues.
Old Jan 11, 2006 | 09:59 AM
  #63
TommyV's Avatar
TommyV
St. Jude Donor '06-'07-'08-'09-'10-'11-'12, '16
Originally Posted by SDCEB
Try Qualcomm Stadium.
I'm going to have to try that. Will an 1/8 mile tell me anything? What are the A4's running?
Old Jan 11, 2006 | 03:35 PM
  #64
mikeyc6's Avatar
mikeyc6
Originally Posted by C6Monty
They're the ones that START (automatically).
70-80% of the 05 MN6 owners and 100% of the 06 MN6 owners have no idea what you are talking about.
Mike
Old Jan 11, 2006 | 07:42 PM
  #65
racedrvr's Avatar
racedrvr
DBS?
Old Jan 11, 2006 | 08:35 PM
  #66
SoldSyclone's Avatar
SoldSyclone
I should be going to Las Vegas Motor Speedway 1-27!
I have about 2,500 miles on my week old A6, I took her up to the mountains and ran the Gtech she ran 13.0 at 116 details 2,500 feet, 37psi, TC off with some tirespin, trans in S automatic mode.
With my old Syclone the Gtech was always within a tenth and 2 mph higher than the track Gtech reads mph at the end of the 1/4 and the track avgs the last 60 feet.
Old Jan 11, 2006 | 10:45 PM
  #67
fdxpilot's Avatar
fdxpilot
37 psi!! You can probably pick up a tenth or two by dropping the pressure to 30psi, where it's supposed to be.
Old Jan 11, 2006 | 11:25 PM
  #68
SoldSyclone
I think you are correct but with the low low stall it seems with the little bit of tire spin I get to the power sooner... need to do some more testing.
Do you run your cold psi below 30? I set mine at 34, 37 was hot.
Old Jan 12, 2006 | 03:33 AM
  #69
fdxpilot's Avatar
fdxpilot
Admittedly, I have a C5, but the doorjamb sticker says 30psi cold. I used that as a starting point, but was getting center wear in the rears, so I adjusted them. I now run 30 front/28 Rear cold. When the track opens up again in the spring, I'm going to try dropping the rears a few more pounds (only at the track) as my new headers have upped my power to near LS2 levels.
Check your doorjamb for the load and tire sticker. I'll bet it is around 30. While overinflating your tires will give you some spin off the line, it will give you less traction once you hook up, and probably in the corners, as well. It will also lead to the excess wear in the center of the tires.
