Tire sensor question regarding pressure changes
Old Jan 8, 2006 | 09:57 PM
Rob4092xx's Avatar
Rob4092xx
Default Tire sensor question regarding pressure changes
I live in Phoenix and have noticed that my tire pressure will change from 28 psi cold, to as high as 35 psi when I am driving on the freeway.
This is a significant change in pressure. Why don’t my tire sensors go off indicating such a pressure increase and/or drop? I thought they were supposed to alert to any significant changes in pressure.
Old Jan 8, 2006 | 10:17 PM
ajw22's Avatar
ajw22
St. Jude Donor '06
Cold tire pressure should be 30.
It is normal for tire pressure to increase as the tires heat during usage.
Page 5-67 in the Onwers Manual:
The TPMS also uses the DIC to warn the driver when air
pressure, in one or more of the tires, falls below 24 psi
(164 kPa) or is above 42 psi (290 kPa).
Old Jan 8, 2006 | 10:24 PM
jmess's Avatar
jmess
The TPM doesn't care what the difference between cold and hot pressures are. The threshold for warnings are:
High pressure warning = anything above 42PSI
Low tire pressure warning = anything in 5-25 PSI range.
Flat tire warning = anyting below 5 PSI.
The recommended cold pressure is just that, the cold pressure. As you drive the car seeing an increase in pressure is normal. 7 PSI over cold is nothing to worry about. GM and GoodYear feel the tires are fine until you exceed 42 PSI. That is why the TPM issues a high pressure warning above 42 PSI.
Old Jan 8, 2006 | 10:49 PM
orca1946's Avatar
orca1946
Thanx for the info.
Old Jan 8, 2006 | 11:27 PM
corvette pilot's Avatar
0corvette pilot
Former Vendor
actually, the low pressure comes on at 23 psi, at least in my car. At 60 degrees, my pressure gage reads 30 psi, but the sensors read 25. When it gets cold, it obviously reads lower, and at 24, there is no warning. At 23 there is, and it goes out when they hit 24.
To Tire sensor question regarding pressure changes
