More HP than...
Old Jan 13, 2006 | 10:22 AM
C8-Vette's Avatar
C8-Vette
Default More HP than...
Old info about Jay Leno driving Z06 pace car. But for the first time in the history of the Daytona, the pace car with 505HP will exceed the power of the event cars which are limited to 450 HP.
Old Jan 13, 2006 | 11:39 AM
Miaugi's Avatar
Miaugi
What are "event cars"? Certainly not the race cars???
Old Jan 13, 2006 | 11:44 AM
serendipity's Avatar
serendipity
Yes. They are limited on "fast" tracks to about 450hp, as opposed to the usual 700+ hp.
Old Jan 13, 2006 | 11:54 AM
Buffy's Avatar
Buffy
Yeah - the IRL specification say "3.5 liters normally aspirated". The hot engine for this is the Honda HI3R, which is rated 650+ HP @ 10,300 RPM. Do they have lower RPM limits for some tracks?
Old Jan 13, 2006 | 11:57 AM
Datawiz's Avatar
Datawiz
CI-7-8-9-10 Veteran
Cruise-In IX AutoX Winner
St. Jude Donor '05 thru '11,'19,'22,'25
St. Jude/CI Name Tag Designer
Umm, I think they're referring to the Daytona 500 which is NASCAR and not IRL.
At Daytona, the engines are restricted to about 450hp. Maybe Leno shouldn't pull off after the pace laps, and instead go head to head with the big boys
LS1LT1's Avatar
LS1LT1
Is it that low? I knew with restrictor plates and such that they were down on power but I really didn't think it was THAT much.
Old Jan 13, 2006 | 12:01 PM
Jagcvette's Avatar
Jagcvette
That's shocking. I can't believe that most moded vettes have more hp then the cars running Daytona.
Old Jan 13, 2006 | 12:08 PM
serendipity
The real cars also probably weigh half of what a Z06 does - I don't see the Z keeping up with them for long
Old Jan 13, 2006 | 12:14 PM
torquetube's Avatar
torquetube
NASCAR Nextel Cup cars have a minimum weight of 3,500 pounds, some 400 pounds heavier than the Z06.
Old Jan 13, 2006 | 12:30 PM
Miaugi's Avatar
Miaugi
I wasn't aware of that...to me the 700+ sounds much more realistic.
Originally Posted by Datawiz
...Maybe Leno shouldn't pull off after the pace laps, and instead go head to head with the big boys
Yeah, I'm sure Jay would be up for that....and he can bring along his buddy..Dennis Gage!
Old Jan 13, 2006 | 01:35 PM
ttomczak's Avatar
ttomczak
St. Jude Donor '06
You are thinking V8's not IRL engines...
c5rulz's Avatar
c5rulz
The cars are not limited in terms of horsepower. The restrictor plate limits the amount of air that can physically pass into the motor reduces the horsepower.
It would be interesting to see what kind of qualifying lap the Z06 would do with a pro driver.
Old Jan 13, 2006 | 01:47 PM
serendipity
I didn't realize that - thanks
Old Jan 13, 2006 | 01:52 PM
TMyers's Avatar
TMyers
Just my opinion mind you but I would bet it would run as fast. Oh ya, the Busch cars have more hp than the Cup cars for Daytona. No restrictor plate for the Busch cars.
Old Jan 13, 2006 | 03:57 PM
Indy-hp's Avatar
Indy-hp
St. Jude Donor '09
If a stock Z06 ran the Daytona 500 with race tires and the suspension adjusted properly, it would win, hands down. The Z06 is more aerodymanic, has 55 more hp, and is at least 300 lbs. lighter than a Cup car at Daytona. Cup car motors make about 650 hp normally, but run with restrictor plates at Daytona and Talledega to reduce hp to about 450 because those 2.5+ mi. tracks would see "unsafe" high speeds on the long straights at those tracks otherwise.
Old Jan 14, 2006 | 02:37 PM
KENZ51's Avatar
KENZ51
Now theres some good information! Thanks!!
Old Jan 14, 2006 | 02:39 PM
User 81424's Avatar
User 81424
The plates have four one inch holes, if I remember correctly, very small.
To More HP than...
Old Jan 14, 2006 | 05:35 PM
2005ArcticWhite's Avatar
2005ArcticWhite
St. Jude Donor '05 thru '11,'18,'20,'21,'24,'25, '26
Old Jan 14, 2006 | 06:25 PM
Buffy's Avatar
Buffy
My stupidity. I'd just finished looking at Indy pace car pictures and so that was on my mind. So I was thinking IRL and ... well, there I go making a fool of myself again. That's twice it's happened now
Old Jan 14, 2006 | 06:36 PM
Nort's Avatar
Nort
I wonder if a stock Z06 could last 500 miles at race speeds? It would be an interesting test.
