Another push button starter question.
Old Jan 13, 2006 | 11:11 AM
70 LS1's Avatar
70 LS1
Default Another push button starter question.
When starting the engine you just push the button and the computer engages the starter then disengages it when the car is running. How does the car know the engine is running and stop cranking?
Old Jan 13, 2006 | 11:27 AM
cranky's Avatar
cranky
the computer reads rpm constantly. after about 300 rpm it disengages the starter. it also reads maf sensor, etc. crancky
Old Jan 13, 2006 | 12:30 PM
f152tall's Avatar
f152tall
It's magical.
Old Jan 13, 2006 | 12:33 PM
jgraditor's Avatar
jgraditor
St. Jude Donor '08
OK here is a question, did not think it was worthy of it's own thread....
If car is running and you are cruising on the tollway at around 60 mph (hey it might happen!) and you by accident hit the button and turn the car off, do you have to hit the clutch and brakes to restart??
Old Jan 13, 2006 | 01:02 PM
toolking's Avatar
toolking
I would venture a bet that it operates the same as a conventional starter. The button isn't magic .. just closes a circuit to activate the starter. When the engine fires the gear is spun back off the fly wheel. Nothing new or high tech. Remember that early cars were button started.
I doubt the computer has much if anything to do with it.
Old Jan 13, 2006 | 01:08 PM
mforman42's Avatar
mforman42
The 'Bendix' engages the starter gears into the flywheel. When the flywheel starts spinning faster than the starter gears, it is disengaged. Been doing it the same way since the early 20th century.
Old Jan 13, 2006 | 01:12 PM
rosemaryburm's Avatar
rosemaryburm
From: Heaven, for the climate; Hell, for the company
Reminds me of those old SNL skits with Billy Crystal and some other guy, one would say "Boy, my shoulder hurts, a lot like the pain I get when I..." And the other guy says " ...go down to the car wash and use the wand to clean out your ear wax, you put in the quarter and select 'hot rinse' and shove the wand all the way in your ear till water squirts out your ***?" "Yeah, I hate when that happens."
Old Jan 13, 2006 | 01:18 PM
toolking's Avatar
toolking
Thank you ... couldn't remember the name of the darn thing! Just rebuilt the starter on my 72 350 Coupe. Old timers disease.
Old Jan 13, 2006 | 01:23 PM
serendipity's Avatar
serendipity
That's not the same question. Of course that's why the car starts, but that doesn't explain how the car "knows" to disengage the starter. Otherwise it would grind. There's obviously some feedback from the crank angle sensor to the starter to that it doesn't keep cranking once it starts.
Old Jan 13, 2006 | 01:35 PM
ttomczak's Avatar
ttomczak
St. Jude Donor '06
Magic...
Old Jan 13, 2006 | 01:40 PM
vettnutt's Avatar
vettnutt
With all the stuff these computers monitor today, don't ya think it knows when the engine is running?
Old Jan 13, 2006 | 01:48 PM
lytmup's Avatar
lytmup
You will blow the mufflers off of the car by doing a stunt like that. (ask me how I know)
I did that one time on a car with a regular ignition to try and "impress" my GF with my knowledge. Well, when I turned the ignition back on while the car was still running, I thought that I had been shot by a cannon by the LARGER than I had ever heard backfire. So, when I went to investigate things after I had stopped, the muffler had literally exploded and split apart at its weld seems.
Needless to say, my GF was less than "impressed"
Old Jan 13, 2006 | 01:59 PM
Al Engel's Avatar
Al Engel
"PFM" technology - - - - Pure F$%*#@n' Magic!
Old Jan 13, 2006 | 02:14 PM
DigitalGriffin's Avatar
DigitalGriffin
MuHaHaHaHaHa
Actually I did that once with my manual. My girl asked. "Can I have the keys?" I then took that car out of gear, and turned the engine off. I then tried to hand them to her. She freaked. I put the key back in, pushed in the clutch and restarted without issue. Guess I was lucky.
Ahhh yes the stupid things we do in our teenage years.
bradb's Avatar
bradb
St. Jude Donor '06-'07
BWAHAHAHAaaaa... how about a spew warning. Now, I have Diet Coke all over my Powerbook. That is hilarious.
Old Jan 13, 2006 | 05:31 PM
haljensen's Avatar
haljensen
Similar stunt used to be an everyday deal with Ford flathead V8's. Run it up in 2nd gear, turn the key off, pump the gas 5-6 times and turn the key back on. Enough raw gas had accumulated in the exhaust that we got a really impressive backfire everytime.
Old Jan 13, 2006 | 06:52 PM
double eagle's Avatar
double eagle
To Another push button starter question.
Old Jan 14, 2006 | 07:20 PM
2005ArcticWhite's Avatar
2005ArcticWhite
St. Jude Donor '05 thru '11,'18,'20,'21,'24,'25, '26
Old Jan 14, 2006 | 07:55 PM
dark_phantom's Avatar
dark_phantom
From: Central Florida. Black Sheep Squadron Member. 465 rwhp & 477 rwtq
Cruise-In VIII Veteran
St. Jude Donor '07
Funniest post I've ever read.
Old Jan 14, 2006 | 08:12 PM
stabori's Avatar
stabori
St. Jude Donor '08
I've done it, Yes the car shuts off. I stepped on the clutch and hit the MAGIC button and she started. NO problem
