Jack Pucks???
:bb
But I never did it deliberately becaue the puck hangs down (of course!) and is not rounded off. That makes it easy to snag on speed bumps, road debris, etc. You'd lose the puck and possibly bend the slot in or out depending on what you hit.
I'm really tempted to get the BMW pads, their rounded profile should make them OK to leave in 24/7.
P.S.
If you go to a shop (tires?) that uses one of those lifts with a single lift post in the middle and 4 arms that angle out to the jacking points, use double pucks- the arms will bow down under the weight of the car and cause the center post to poke your plastic/balsa floor. Ugh. Glad another member told me about that one in advance!
:bb
P.S.
:bb
P.S.
Does that sound reasonable, or is their a smarter/better way to do it?
I haven't put the BMW pucks on yet (sorry to keep using that term!), not sure how much clearance they are going to require relative to other underbody protrusions.
Also, once they go on, it appears (from their construction) that you can just pry/them off, but they otherwise will stay put. Yes?
Comments from others with I3 /\/\ VV pucks??
(This forum has got to be the greatest thing since bacon was invented!)
I haven't actually seen the BMW pads, but don't they have a rounded surface instead of the flats on hockey pucks? If they ARE rounded, then trying to lift them with a flat puck might get wobbly. Any comments?
hard rubber hockey pucks with an eye bolt screwed into the center of each puck - work like a champ!
