song list
Old Jan 24, 2006 | 09:00 PM
nuvetteowner's Avatar
nuvetteowner
Default song list
Does anyone know how to use the song list? I tried to use it but the songs disapear after I remove the CD? Is this feature suposed to save the songs for play back without the CD inthe player?
Old Jan 24, 2006 | 09:47 PM
mpuzach's Avatar
mpuzach
The song list is only a display of tracks that are on a CD that's inserted into the player. Once you remove the disc, the list disappears. You can't play tunes unless the disc is in the player.
Old Jan 25, 2006 | 09:09 AM
footba4672's Avatar
footba4672
where is that feature on the radio
Old Jan 25, 2006 | 09:32 AM
63C663's Avatar
63C663
According to my manual, it says you are able to store 20 songs in a song list. You don't need the CD in the player to play them. This would be up to 20 songs that you choose. You can add and delete songs from the list. It's in the manual and it's called Song List.
Old Jan 25, 2006 | 09:45 AM
CamaroCane's Avatar
CamaroCane
Ya I thought so too, but when the CD is removed so is the song list
Old Jan 25, 2006 | 11:27 AM
orca1946's Avatar
orca1946
I tried that with the same results
Old Jan 25, 2006 | 11:33 AM
Mayonayze's Avatar
Mayonayze
From: Prepare yourself, for a pride obliterating bich smack. Fairfax, VA
St. Jude Donor '06-'07-'08
SEC > BCS 4 St. Judes '09
interesting. i thought for a second there that maybe my C6 had the same capability that the new bimmers have. where you can actually save MP3 files to your car stereo and compile song lists. that would have been cool. alas, it appears this is not the case. :o
Old Jan 25, 2006 | 01:31 PM
63C663's Avatar
63C663
The real question is - Why did they put it in the manual?
Old Jan 25, 2006 | 11:55 PM
nuvetteowner
Default manual
The maual is quite misleading on that information,No one else seems to know how to do it. If you can do it your info on the procedure would be helpful.
Old Jan 26, 2006 | 12:11 AM
Jagcvette's Avatar
Jagcvette
Maybe its a list of songs you can choose to play in the order that you select from the CD.
Old Jan 26, 2006 | 12:54 AM
greentank's Avatar
greentank
actually, it specifically says it saves 20 songs. I just read it in the manual. Cool feature...if it exists. If it doesnt, Chevy should replace the radio under warranty????
Old Jan 26, 2006 | 01:16 AM
russ527's Avatar
russ527
Cruising
It is only a list of songs selected from the CDs currently in your player. The manual states, "If a CD is ejected, and the song list contains saved tracks from that CD, those tracks are automatically deleted from the song list." So the list just allows you to choose the tracks you want to hear and skip over the ones you don't.
Old Jan 26, 2006 | 09:34 PM
nuvetteowner
Default song list
Yes that is what it always did,I just wanted to make sure I wasn't missing out because of lack of info! Thanks for the reply!
To song list
