Vin # Question
Old Jan 28, 2006 | 01:52 PM
ENM's Avatar
ENM
Default Vin # Question
Is it correct to assume that if you have two vin #s, and you take the last 8 digits, that the higer numbered was built later than the lower # ?
Old Jan 28, 2006 | 01:55 PM
Lawman31's Avatar
Lawman31
The last 5 I believe represent the production number.
Old Jan 28, 2006 | 02:15 PM
BigJoe's Avatar
BigJoe
And yes, higher number = later production date
Old Jan 28, 2006 | 02:28 PM
ENM's Avatar
ENM
Would the difference in the two numbers reflect the number of cars built in between ?
Old Jan 28, 2006 | 03:05 PM
BigJoe's Avatar
BigJoe
Yes. Its a sequential number.
Old Jan 28, 2006 | 07:35 PM
Vette_DD's Avatar
Vette_DD
Difference in number for the last 6 digits only, not the last 8 digits.
The difference between 65100018 and 55100018 does not mean that 10000000 cars have been built because the 6 in the indicated position is the model year number.
For the same model year, however, the difference in the last 6 digits of the VIN would indicate how many cars were built in between.
Old Jan 28, 2006 | 08:43 PM
Nicks06C6's Avatar
Nicks06C6
Default Corvette VIN breakdown
Here's the breakdown of the VIn on your Corvette
Position 1 2 3 World Mfg ID
1 G 1 USA
Position 4 5 Platform/Series
Y Y Corvette
Position 6 Body Style
2 2 Door
Position 7 Restraint Type
6 Active Belts
Position 8 Engine Type
U 6.0L V8
Position 9 Check Digit
6 GM Assigned
Position 10 Model Year
6 2006
Position 11 Factory ID
5 Bowling Green, KY
Position 12, 13, 14, 15, 16, 17 Build Sequence Number
112525 12,525th Corvette built
So the VIN would be:
1G1YY26U665112525
Thia VIN is different for Convertible and Z06, but gives you an idea what the numbers mean. Hope this helps.....
Old Jan 28, 2006 | 09:14 PM
Corvette Junkie's Avatar
Corvette Junkie
Night Race Blue 427
From: Muncie, Indiana ...... Can I buy an amplifier on time ... I ani't got no money now but I'll pay you before I die
2 2 Door
2 2 Is for coupe
3 3 Is for Convertible
Old Jan 28, 2006 | 09:45 PM
Vette_DD's Avatar
Vette_DD
2 2 Is for coupe
The VIN info. I had indicated a 1 in the 6th position was for FRC. Is that correct?
Old Jan 28, 2006 | 11:17 PM
double eagle's Avatar
double eagle
VIN DECODES: This is an example of a VIN # for a 2006 Corvette Coupe:
1 G 1 Y Y 2 x U y 1 6 1 0 0 0 0 1
There are 17 characters. Starting with first character on left the codes are:
1. "1"= Built in US
2. "G"= General Motors
3. "1"= Chevrolet
4. “Y” = Corvette body style
5. “Y” = provides more info about the car, usually a "Y"
6. “2” = coupe ("3" = convertible)
7. “x” = restraint code
8. “U” = LS2 engine
9. “y” = check digit
10. “6” = 2006 model year
11. “5” = Bowling Green plant
12-17. Production sequence number (starts with 100001 for each model year)
What's FRC?
Old Jan 28, 2006 | 11:43 PM
Vette_DD's Avatar
Vette_DD
1. "1"= Built in US
3. "1"= Chevrolet
8. “U” = LS2 engine
What's FRC?
Fixed Roof Coupe, as in Z06.
Old Jan 29, 2006 | 12:08 AM
Jagcvette's Avatar
Jagcvette
Show off!
Old Jan 29, 2006 | 12:11 AM
ENM's Avatar
ENM
1 G 1 USA
Y Y Corvette
2 2 Door
6 Active Belts
U 6.0L V8
6 GM Assigned
6 2006
5 Bowling Green, KY
1G1YY26U665112525
Thanks that is exactly what i needed.
Old Jan 30, 2006 | 06:52 PM
b4i4getit's Avatar
b4i4getit
The sequence number only identifies when a car starts down the line. If it is shuttled off to a repair area for significant problems it is possible that a car with a later sequence number will be completed and off the assembly line before the other car.
To Vin # Question
