Runflat question
Old Jan 29, 2006 | 07:03 PM
Ginny C6's Avatar
Ginny C6
CI 6-7-8-9-10-12 Veteran
St. Jude Donor '11
Default Runflat question
Got up this morning to find I had a flat on my left rear, due to a nail. There were no Goodyear dealers open so I went to Tire Kingdom, where they told me you are not supposed to patch run flats. If there is a nail in the tire it should be replaced. Are they right?
Old Jan 29, 2006 | 07:05 PM
sallen619's Avatar
sallen619
No! The correct method of repair is the plug/patch. Put some air in it and find an authorized Goodyear dealer. It'll probably be fixed for free. I've had 2 fixed.
BigJoe's Avatar
BigJoe
True only if its near the sidewall, like any other tire. It should be patched from the inside, though, to preserve the speed rating.
Old Jan 29, 2006 | 07:06 PM
Steve Germany's Avatar
Steve Germany
No - but they do have to be trained to do it correctly. It requires a plug and a patch. In any case you may be under warrenty - go see the dealer.
Old Jan 29, 2006 | 07:12 PM
burtonbl103's Avatar
burtonbl103
St. Jude Donor '06-'07-'08,'12-'13
A true goodyear dealer can patch one of those tires !
Old Jan 29, 2006 | 07:17 PM
fredgpowell's Avatar
fredgpowell
Yea take it to the dealer ship. Tell them you want change for a dollar and go to the side of the building and get some air. Then get it to the dealership and they will take care of it and inspect the other tires. Hope that helps
Wcberry's Avatar
Wcberry
Cruise-In VII Veteran
The correct way and the wrong way to fix a flat.
Old Jan 29, 2006 | 07:21 PM
shopdog's Avatar
shopdog
Run, don't walk, away, far away, from this tire store. They don't know how to repair Goodyear EMTs. Goodyear has a specific procedure for repairing punctures in EMTs. Not even all Goodyear dealers are authorized to do it. Call the number in the Goodyear warranty booklet that came with the car. They can give you a list of authorized Goodyear repair centers near you.
Note that punctures are covered by the Goodyear warranty for 12 months or 2/32 tread wear. If your car falls inside those limits, the repair (or replacement if the tire should prove to be unrepairable) should be absolutely free.
I've had two flats, one repairable, one requiring replacement of the tire, both were done absolutely free by Goodyear under the warranty. I did have to wave the warranty booklet under the nose of one Goodyear Tire store manager. He wanted to charge me for the repair (and then bill Goodyear, double dipping scum).
Old Jan 29, 2006 | 07:23 PM
JELSIS's Avatar
JELSIS
Good info, I didnt know you could do both at the same time.
Old Jan 29, 2006 | 07:52 PM
Ginny C6's Avatar
Ginny C6
St. Jude Donor '11
Here's a couple of details I failed to say in my original post. I was 200 miles from home this morning, and NO Goodyear dealers in the Ft. Myers area were open. I had no choice (other than driving home at less than 55 mph the whole way) but to let them patch, not plug it. And yes the car is 15 months and 9200 miles old. I'm just wondering if I should replace it now. And BTW, On Star and my GPS sure came in handy!
Old Jan 29, 2006 | 08:29 PM
Mocoso's Avatar
Mocoso
If you do decide to replace it and/or have a "Goodyear" place fix it right be warned that calling the 800 number to get the "authorized" place wont guarantee you dont get a bunch of monkeys to work on it... place I was sent to by the 800 number (a GOODYEAR TIRE SHOP I MAY ADD) had the manager who had no clue about warranty on the tires, argued with me that since he hadnt heard of it it didnt exist (prob. wanted to double dip as shopdog's experience) and a mechanic who wanted me to drive up to his lift which was sticking 12 inches off the ground... they can be fixed but be sure you find a place that knows how as others have already stated
Old Jan 29, 2006 | 08:33 PM
xs650's Avatar
xs650
A good tire shop should be able to clean up Tire Kingdom's mess and patch and plug it correctly.
Old Jan 29, 2006 | 08:38 PM
VET4LES's Avatar
VET4LES
I was sent to an off brand shop for repair and they would not honor the waranty. I called the 800 number back and they told me to pay for it send them the bill. I did and received my check in about one week.
Old Jan 29, 2006 | 08:40 PM
jkonkle's Avatar
jkonkle
Go big or don't go...
Find an EMT certified tech using this tool
http://goodyeardealers.com/
even if it is 30miles away it's worth taking it in. The best part is you can drive it there
I will never allow someone who isn't emt certified to work with my EMTs again - been there.
Hey - how close is that cabin to the Virginia International Raceway??
JK
Old Jan 29, 2006 | 08:47 PM
Driver_WT's Avatar
Driver_WT
St. Jude Donor '07
I would be very careful about fixing a runflat tire if it has been used in runflat mode for any distance. If the tire held air, and it is inflated to the proper pressure, then it is no longer in runflat mode and you can drive it prior to getting a proper repair.
Old Jan 29, 2006 | 09:26 PM
54greg's Avatar
54greg
Great pics of the correct repair. Thx
Old Jan 29, 2006 | 09:27 PM
Ginny C6's Avatar
Ginny C6
St. Jude Donor '11
I only drove about 20 miles never exceeding 45 mph. And the cabin is 270 miles from V.I.R.
To Runflat question
Old Jan 29, 2006 | 09:59 PM
Vette_DD's Avatar
Vette_DD
The 2/32" of treadwear or 12 months that shopdog mentioned is whichever comes first. Since you've got over 12 months on those tires, it's prorated when GoodYear gets ready to replace it. Not sure how they handle the cost of repair.
Old Jan 30, 2006 | 03:58 PM
Ginny C6's Avatar
Ginny C6
St. Jude Donor '11
Thanks for the info. The first Goodyear dealer didn't know about a plug patch. I called a second one and he agreed with this photo that this is the way to repair it. It's going to be $25.00 plus balance. Thanks, Kevin
Old Jan 30, 2006 | 04:05 PM
BIGGGIE's Avatar
BIGGGIE
St. Jude Donor '05-'06-'07-'08
kevin it should be free...its under 12,000 miles.. look at your owners manual..
