Jacking Pucks
Old Jan 30, 2006 | 07:40 AM
BlackZ51Vett's Avatar
BlackZ51Vett
Default Jacking Pucks
Anyone know if jacking pucks are required on the C6.
Old Jan 30, 2006 | 07:44 AM
Another Yellow's Avatar
Another Yellow
St. Jude '03-'04-'05-'06
You risk damage if you jack the car from that point and don't use them. The C5 pucks work fine.
Old Jan 30, 2006 | 08:00 AM
BlackZ51Vett
Thanks. I figured that much. They are good insurance against damage. Was just wondering if anyone and how many readers jack without pucks.
Old Jan 30, 2006 | 08:04 AM
Velocity Jonny's Avatar
Velocity Jonny
Well, I jack using little blocks of wood that act like pucks. My goal is to keep the metal from the jack away from the plastic sides of the car. The wood block just acts as a spacer.
Old Jan 30, 2006 | 08:05 AM
Ucraz-E's Avatar
Ucraz-E
I personally jack without them, only because of my laziness in not buying them yet. Then again, I watch what I'm doing.
A dealer on the other hand might not be as careful as you and I would.
Old Jan 30, 2006 | 09:52 AM
jnx911's Avatar
jnx911
You can use just about anything, wood, hockey puck etc,etc. it's just to act as a spacer so the jack does not come into contact with the bottom of the car. I have 2 jacks and with one, I need the spacer, and with the other I do not. Just be careful and pay attention and you will be ok.
Old Jan 30, 2006 | 11:10 AM
Dave S's Avatar
Dave S
Retired & lovin' it!
Hockey pucks work just fine & they're just 99 cents in most sporting goods stores...
Old Jan 30, 2006 | 12:27 PM
quickride's Avatar
quickride
For the very small expense of picking up some pucks, why take any chance at all of damaging your car. You can make these things yourself if you want to do all the running around to the various stores or you can pick them up all the time on ebay.
I have a set like these and they work great. My buddy uses some of these on his C5. Check the link below.
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMESE%3AIT
To Jacking Pucks
