HELP-Climate Control Screen Cracking
Old Feb 5, 2006 | 02:29 PM
SellingBMWforC6's Avatar
SellingBMWforC6
Default HELP-Climate Control Screen Cracking
Noticed little spider cracks in the lower left hand corner of the climate control screen a few days ago. Now, the cracks have spread another quarter inch or so and I can see more cracks forming in the lower right hand corner. I've had the car 6 weeks or so and am sure the cracks were not there initially. Has anyone else experienced this? What would cause this? Vibrations? Temperature changes? I am sure the dealer will have to pull and replace the whole unit to fix it - How big a job is this? Anyone think I will have a problem getting the dealer to fix under warranty?
Old Feb 5, 2006 | 02:38 PM
2005ArcticWhite's Avatar
2005ArcticWhite
St. Jude Donor '05 thru '11,'18,'20,'21,'24,'25, '26
No problems here. Best of luck to you.
Old Feb 5, 2006 | 02:43 PM
67Roadster's Avatar
67Roadster
See the dealer
donsar's Avatar
donsar
Never heard of this problem before. I feel confident that you should be able to have it corrected under warranty without difficulty.
Old Feb 5, 2006 | 02:44 PM
millpond's Avatar
millpond
Haven't heard of that problem before, but should be covered under your warrantee.
Old Feb 5, 2006 | 03:09 PM
corvettetanner's Avatar
corvettetanner
See your dealer first thing tomorrow morning.
Old Feb 5, 2006 | 03:49 PM
BlackZ51Vett's Avatar
BlackZ51Vett
No problems here either. Dealer should fix with no problems.
Old Feb 5, 2006 | 10:43 PM
double eagle's Avatar
double eagle
Should be a warranty fix-it
To HELP-Climate Control Screen Cracking
