...would an '05 4 speed auto with a 3.15 be quicker than an '06 6 speed auto with a 2.56....what about the '05 with the stock 2.73 compared to the '06. Comparing automatics only ... this doctor doesn't want to shift gears unless it's paddle shift.
Sometimes the A4 will be slightly faster from a roll, sometimes the A6, depends on the starting speed. They're close to the same from a dead stop, according to Corvette Quarterly magazine & GM.
A4 with 2.73 might be just a little slower from the stop than A4 with 3.15.
The definitive answer is "it depends". It depends on the rpm range you are in when you hit it. If you are in a good power range you will get better performance. The advantage to the A6 is that it is in the best rpm ranges more of the time. The disadvantage is that it has to shift more to get in those ranges. The end result is they are very close, so close that choosing between them is almost a moot point. (This is comparing the 3:15 A4, the 2:73 A4 would be noticeably slower in all rpm ranges). So discounting performance what else is there to differentiate them. Obviously the paddles on the A6. If you want closer control the paddles are the way to go.
