MN6 owners.....
Old Feb 8, 2006 | 05:16 PM
gilly6993's Avatar
gilly6993
St. Jude Donor '08
Default MN6 owners.....
....anyone ever use 6th gear at all?
Old Feb 8, 2006 | 05:18 PM
rodfl99's Avatar
rodfl99
Usually not until I go over 60..........
Hoonose's Avatar
Hoonose
Almost anytime over about 40 mph.
ketchup's Avatar
ketchup
very very very rarely.
Old Feb 8, 2006 | 05:19 PM
duelly777's Avatar
duelly777
Only on Interstate Hwy trips or roads with similar speed limits. 65 and under I never use 6th
Flatbush_Harry
Guest
Posts: n/a
All the time on the freeway...great gas mileage and I downshift to 4th or 5th for passing.
Harry
Old Feb 8, 2006 | 05:21 PM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
As long as I'n not in very heavy traffic then. Leave it in 5th then for a quicker response if needed
3and8fan's Avatar
3and8fan
St. Jude Donor '07-'08-'09-'10-'11
Harry
Old Feb 8, 2006 | 05:24 PM
Swave Dave's Avatar
Swave Dave
REPLY: Anyone know the maximum h.p./tq capability of the 6 speed gearbox ?
Old Feb 8, 2006 | 05:26 PM
SellingBMWforC6's Avatar
SellingBMWforC6
Lot of times go straight from 4th to 6th if don't need the power.
Old Feb 8, 2006 | 05:27 PM
dashotgun's Avatar
dashotgun
yes if I am cruising in to work.
Old Feb 8, 2006 | 05:36 PM
gilly6993's Avatar
gilly6993
St. Jude Donor '08
interesting.....I never use it....even at cruising as highway speeds of 75 and above....I'll have to start though for better mileage.....
Old Feb 8, 2006 | 05:51 PM
66dreams's Avatar
66dreams
I'm used to high revving cars so I didn't use it or even 5th that much at first. Now if I'm cruising I'll go to 5th above 45 and 6th above 50 like the owners manual indicates. Otherwise I'll keep it in 4th or below for more brisk driving. You're not lugging the LS2 in the upper gears until you get it below ~1000 rpms. Even there it's making over 250 lb-ft of torque based on a graph I saw. (Assuming that graph is correct.)
H&J's Avatar
H&J
Harry
Same Here. Blew away my brother by doing 80 at 2000 rpm. He has a '66 GTO that probably tachs 4000 at 80 mph
Old Feb 8, 2006 | 05:55 PM
67Roadster's Avatar
67Roadster
70 and above
Old Feb 8, 2006 | 06:05 PM
Rube66's Avatar
Rube66
Only during break-in since I wanted to be sure and go through every gear.
Old Feb 8, 2006 | 06:17 PM
Steve Germany's Avatar
Steve Germany
Not very often - I have to think about it. I wish the gear ratios were more realistic but on the other hand I do not want to pay the guzzler tax. All in all GM did a great job on keeping the C6 (and ZO6) an every day man's car! Here, Here - GM!!
To MN6 owners.....
Old Feb 8, 2006 | 06:24 PM
fredgpowell's Avatar
fredgpowell
Only on the highway or when i have open road that i dont want to abuse the highway. Rare but i do use it. But then again i live in Boston hard to get to 6th with all the traffic.
Old Feb 8, 2006 | 06:29 PM
wewing's Avatar
wewing
I use mine at about 45mph and over.
Old Feb 8, 2006 | 06:30 PM
cmb13's Avatar
cmb13
Every time I get on the highway.
