cd changer help
Old Feb 9, 2006 | 05:13 PM
hog driver's Avatar
hog driver
Default cd changer help
I installed the cd changer today, easy install, BUT I am unable to eject the cartridge using the eject button. The cartridge is empty so I know it is not a disc with a label causing it to stick. Any ideas, dynamite is not an option.
Old Feb 9, 2006 | 05:18 PM
VET4LES's Avatar
VET4LES
Is it the GM unit made for the C6?
Old Feb 9, 2006 | 05:30 PM
hog driver's Avatar
hog driver
Yes it is the GM unit.
Old Feb 9, 2006 | 05:49 PM
VET4LES's Avatar
VET4LES
I would just check all of the obvious things. Is the power on and all of the connections good. How about a ground. I don't have the CD player yet but plan on one soon. How do you eject the cartridge? It could be in wrong. Did it go in easy? Good luck and let us know what happens.
Old Feb 9, 2006 | 11:18 PM
jkonkle's Avatar
jkonkle
Go big or don't go...
unscrew the back cover and push hard on the little switch you can see it - push it to the right/left can't remember.
If you can eject it; try laying it horizontal if it ejects then send that beoch back. I've got two bad ones; since December - ugh crap!
JK
To cd changer help
