Scraping Noise
Old Feb 9, 2006 | 11:04 PM
dolphin2551's Avatar
dolphin2551
Default Scraping Noise
When putting the car in drive having an automatic and starting to move i get a scaping noise, not all the time. Sounds like the air foil in the front is scaping but it's not, tires not hitting wheel wells or anything esle of what i can see. Happens turning or going straight ahead! Need suggestions! Thank you in advance!
Old Feb 9, 2006 | 11:13 PM
STPH8N's Avatar
STPH8N
Thats exactly whats happening to mine and its really getting to me as well. I took it to the dealer and they told me they couldn't find the problem
Old Feb 10, 2006 | 12:56 AM
dolphin2551
Yes Ok, Did The Same Thing Took It To The Dealer I Couldn't Get The Car To Make The Noise, Felt Like A Fool! Will Probally Have To Leave It! Changed The Diff. Fluid Was Told It Could Be That Clutches Making Noise Still Made The Noise! Very Annoying!!!!
Old Feb 10, 2006 | 01:00 AM
Mocoso's Avatar
Mocoso
Check the air duct from the lower air dam up to the wheel well... if it got pushed out it may be scraping against the wheel... also are you hearing this on asphalt or only cement... if only cement is the cement rather smooth like in a parking garage? reason I ask is because my tires do the same scraping sound but only on smooth cement and at very slow speed.
Old Feb 10, 2006 | 07:25 AM
Karfever's Avatar
Karfever
I have the same issue, but feel it may be the rear end, clutch plates locking which puts the car in a 'binding' situation. Doesnt do it all the time, but......
Old Feb 10, 2006 | 07:26 AM
Buy-Low's Avatar
Buy-Low
I get is as well when first moving the car. My C5 did the same.
To Scraping Noise
