05 Dbs
Old Feb 11, 2006 | 03:05 PM
rm50's Avatar
rm50
2020 C8 of the Year Finalist - Unmodified
Default 05 Dbs
It was my own fault. I have owned my 05 Velocity Yellow, MN6, power top convertible for about 6 months. The last time I shut it down I did not shift to reverse, apply the brake or lock the steering column. The result is I came back home after 2 weeks and discovered I had a dead car.
The result is a quick trip to the auto supply store for a battery charger, on the internet ordering a priority start and wasting sunshine and warm weather waiting for my battery to charge.
Old Feb 11, 2006 | 04:02 PM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
[QUOTE=rm50]It was my own fault. I have owned my 05 Velocity Yellow, MN6, power top convertible for about 6 months. The last time I shut it down I did not shift to reverse, apply the brake or lock the steering column. The result is I came back home after 2 weeks and discovered I had a dead car.
QUOTE]
As you said you forgot to put it in reverse. You did NOT HAVE dbs.
You had a case of operator goof up
Live and learn. We all have bad days
Old Feb 11, 2006 | 04:09 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
At least you admitted it.
There have undoubtedly been other instances of the same thing, but some of the owners may not have been willing to admit it. Instead conveniently attributing it to some sort of mysterious "syndrome."
And I suspect that a lot of others didn't either.
As he is bound to have this question raised: "How did you manage to get out of the car at all without putting it into reverse? We have been lead to believe that it is next to impossible to exit the car without it being in reverse. How did you manage to do it?
Old Feb 11, 2006 | 04:11 PM
stabori's Avatar
stabori
St. Jude Donor '08
I never lock my steering column. 1 year(almost) and no DBS. Knock on wood. Also a MN6 MY.
Old Feb 11, 2006 | 04:18 PM
Steve Germany's Avatar
Steve Germany
I'm afraid that your battery may never recover from this two week drain. You will probably want to look into a new battery to go along with the Priority Start. Autozone carries the Optima yellow top deep cycle battery will live through extreame abuse like this.
Old Feb 11, 2006 | 07:26 PM
VET4LES's Avatar
VET4LES
Same here.
Old Feb 11, 2006 | 07:43 PM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Terrible I say. There's nothing worse than a battered battery. Unless it's onion rings.
Old Feb 11, 2006 | 08:16 PM
Hoonose's Avatar
Hoonose
It happened to me once trying to setup the visor garage door opener with one of those rolling code openers. Jumping in and out of the car, up the ladder a few times to hit the 'head' button. Getting in and out. Rushed. Finally got it to work, and just left in a hurry. When I came back 4 hrs later, the car was still on, and in neutral with the obvious DIC warning staring right at me.
A few other times I tried to leave improperly, but the DIC warning and bells kept me in line. It is hard to do, but not impossible.
To 05 Dbs
