C6 vs Snow
Old Feb 12, 2006 | 12:03 AM
VITIS's Avatar
VITIS
Active Streak: 90 Days
St. Jude Donor '15-'16,'18,'19-'20
Default C6 vs Snow
Left home this morning to go into the city about an hour away for a day of shopping. Forecast was for cold with flurries. About half way there we hit these snow showers that became show cloud bursts. In my years of Vette ownership I had never had one out in the snow, I was wishing I had left the Vette at home. With temps in the 20's streets began to get dicey. By the time we headed home dicey became icey. I can report that the Vette handled itself very well. Handling and traction were much better than I was expecting with 400 hp in a rear drive car. One time hit an icey spot under an overpass and the rear end started to kick out but active handling caught it. ABS braking was spot on.
Don't recommend being out in bad conditions with all the SUV loonies around, but I was impressed with the Vette.
Old Feb 12, 2006 | 12:19 AM
Jagcvette's Avatar
Jagcvette
Don't think its the hp that gives us problems as much as the light weight and huge, wide tires. The tires will hydroplane on the snow in a heartbeat.
Old Feb 12, 2006 | 12:20 AM
2005ArcticWhite's Avatar
2005ArcticWhite
St. Jude Donor '05 thru '11,'18,'20,'21,'24,'25, '26
Old Feb 12, 2006 | 04:29 AM
shopdog's Avatar
shopdog
The horsepower isn't a problem. Just don't stomp the pedal to the metal and those horses stay in the tank. The light weight (the Corvette isn't that light at a ton and a half) isn't a problem either. The wide summer tires can be a problem. The snowplow hanging down in the front can be a problem too.
Old Feb 12, 2006 | 05:34 AM
Another Yellow's Avatar
Another Yellow
St. Jude '03-'04-'05-'06
With the transmission in the rear, the Corvette is not your typical rear-wheel drive car. I have the Goodyear All-Season run-flats and the car is fine with 3 inches of snow.
Frank
Old Feb 12, 2006 | 06:25 AM
Steve Germany's Avatar
Steve Germany
I've gone full snows on mine and am very pleased. Although I do not drive it when I know it is going to snow the cold weather compound is much more grippy and fun when the temps are cold.
Old Feb 12, 2006 | 11:49 AM
coolcat's Avatar
coolcat
I drive mine in the snow with the standard run-flats. No problems at all. Why spend extra money for all season run-flats or snow tires? All that extreme cold weather testing of the C6 before it whent into production has paid off bigtime.
Old Feb 12, 2006 | 11:54 AM
david.k's Avatar
david.k
I read that GM did a lot of snow testing in the c6. Also I read that the engine can withstand temps. of below -15 if im not mistaking. Imagin if they had an all wheel drive option, how good it would handle in the snow.
Old Feb 12, 2006 | 12:00 PM
donsar's Avatar
donsar
Never had a problem if I'm careful about the application of power. The big problem is ground clerarnce. So, I stay out of snow as much as possible, but know that if needed I can handle the beast in the bad weather as long as the snow is less then 4" or so
Old Feb 12, 2006 | 12:13 PM
burtonbl103's Avatar
burtonbl103
St. Jude Donor '06-'07-'08,'12-'13
It is just so wrong on so manny levels !
Old Feb 12, 2006 | 12:57 PM
BigJoe's Avatar
BigJoe
I drove mine after a No. TX ice storm. Had to get to work... The ice coverage was about 50% on the roads and the C6 handled quite well. I expected some sipping and got very little during both accelerating or stopping. I wouldn't try doing it for fun, but if you have to drive in the bad stuff the C6 will do the job. Just remember to put the egg on the accelerator pedal AND the brake pedal...
Old Feb 12, 2006 | 01:10 PM
dgrawr's Avatar
dgrawr
I hope I never have the need to do that. Drove my Camaro Z28 in the ice this winter...no choice, and I made it, although I took my sweet time.
Old Feb 12, 2006 | 01:16 PM
cthusker's Avatar
cthusker
Years ago I had 67 coupe 427/435 4spd. It was my "ONLY" car and therefore I had to drive it in the snow. I was never thrilled about doing it but had it out in some pretty bad snowstorms in Connecticut. I always got where I was going but had a few thrills along the way. Bottom line is you do what you gotta do.
Fast forward and my new C6 will never be driven in the snow simply because I have other vehicles to use. I'll bet the C6 is hundred times safer and easier to drive in snow and ice and then my 67 but I don't plan on finding out. To those that have to drive their vetts in crap weather I completely understand where you're coming from. Been there and done that... I think it's still worth having a vett even if it's your only car especially in a certain age group.
Old Feb 12, 2006 | 01:51 PM
double eagle's Avatar
double eagle
- as with any vehicle be careful in the snow and ice...
To C6 vs Snow
