Check engine light ON!
Old Feb 12, 2006 | 03:12 PM
rmp's Avatar
rmp
Default Check engine light ON!
and smoke from oil dipstick when I checked it hot (down 1 quart); replaced oil; engine light still on; no unusual guage readings.
2006 manual Z51 with 1200 miles; Any ideas?
Old Feb 12, 2006 | 03:13 PM
pdmviper's Avatar
pdmviper
Check your gas cap, ensure it clicks at least three times.
Old Feb 12, 2006 | 03:17 PM
nowheelie's Avatar
nowheelie
Do you have Onstar? If yes, give them a call, they could run a remote diagnostic check and let you know how critical it is.
Otherwise, sorry, no help here.
Old Feb 12, 2006 | 03:28 PM
rmp's Avatar
rmp
Default No Onstar and I checked gas cap
will have to bring in to dealer this week.
Old Feb 12, 2006 | 04:12 PM
troy144's Avatar
troy144
Old Feb 12, 2006 | 05:08 PM
vttrod's Avatar
vttrod
Onstar works great for that... Hope you have it.
Old Feb 12, 2006 | 05:47 PM
holdin5aces's Avatar
holdin5aces
Default bin there dun d'at
Owner's Manual says, 'did you recently buy gas?". If yes, it may take several start/shut downs to extinguish the light. Read this section. We reseated the gas cap and it was 2 days before the Check Engine light went off.
Old Feb 12, 2006 | 07:30 PM
own2vettes's Avatar
own2vettes
Have you tried pulling the little bulb out of the "Check Engine" light?
Old Feb 12, 2006 | 08:32 PM
500's Avatar
500
Be glad the light is still on....so when you go for service they will see it and be able to check for the respective code. I've had the light come on then go off and the dealer was unable to find a code!!
Old Feb 13, 2006 | 12:47 AM
rmp's Avatar
rmp
Default I'll let you guys know if
anything significant or of interest turns up.
Old Feb 13, 2006 | 12:53 AM
lt1george's Avatar
lt1george
Default service engine light
Disconnect battery to clear the code. If it comes back on, it's a hard code then bring it to dealer.Like the other forum member said probably just a light for a non tighten gas cap. Good Luck.
Old Feb 13, 2006 | 06:35 AM
AFVETTE's Avatar
AFVETTE
In the owner's manual it lists many pages of problem warings the DIC can display.
Not being able to read and clear the codes like the C5 is going to make GM a lot of money once the warranty expires.
That's why I buying this for my new C6:
http://www.diydiagnostics.com/
Tom
To Check engine light ON!
