06 Automatic Shifter Rattle
Anyone else out there with an 06 A6 with a shifter button that rattles. Mine has been doing this since new. Not very loud, in fact I cant hear it most of the time (worked around jets for 20 years) but it drives the wife crazy. Just trying to fiigure out if this is a isolated case or common. Thanks in advance.
Mine did. I took one of those small felt adhesive pads you stick on the bottom of nik-naks, a pair of tweezers and slide the pad up between the botton and what it presses against inside. Problem solved.
Originally Posted by rbl
Mine rattles ... took awhile to figure it out too. I just press the button and it stops. Seems to start again on certain roads.
