G Meter accuracy??
Old Feb 24, 2006 | 06:02 PM
C6-er's Avatar
C6-er
From: Just another gray haired old fart in a Corvette.
Default G Meter accuracy??
I was on a two lane on ramp yesterday and wanted to pass an 18 wheeler before merging onto the freeway. I whipped up the horses and leaned into the corner pretty good but still well under control. After coming up on the freeway I recalled the G meter reading and it read .91 g’s. No way, is this thing accurate?
Old Feb 24, 2006 | 06:15 PM
SDCEB's Avatar
SDCEB
I think that it is mostly for fun. You get a reading if you are sitting still on a ramp, at an angle.
Old Feb 24, 2006 | 06:32 PM
2005ArcticWhite's Avatar
2005ArcticWhite
St. Jude Donor '05 thru '11,'18,'20,'21,'24,'25, '26
Old Feb 24, 2006 | 07:17 PM
Black04Vert's Avatar
Black04Vert
Gravity is an acceleration force just as much as cornering is. If you're on a surface that is not latitudinally flat then you should get a lateral acceleration reading even parked.
Old Feb 24, 2006 | 07:18 PM
xs650's Avatar
xs650
You can check the accuracy by tipping your car onto it's side. It should read 1 g.
Old Feb 24, 2006 | 11:39 PM
greentank's Avatar
greentank
THAT was funny.
Old Feb 24, 2006 | 11:46 PM
C-INRED's Avatar
C-INRED
St. Jude Donor '06
It also follows that if the car can pull 1 g, you should be able to set it on the side of a concrete wall and it should stay there!
Old Feb 25, 2006 | 12:31 AM
leeman's Avatar
leeman
Default Yes
You should be able to handle .91G's with the stock suspension according to GM. The Z51 is rated at .98 G's. I pulled .89 with my stock suspension C5 using a G-tech pro to measure it.
Old Feb 25, 2006 | 12:48 AM
Onyasix's Avatar
Onyasix
If you go around a 90 degree embankment at 150 mph, it should read zero.
Old Feb 25, 2006 | 01:39 AM
millpond's Avatar
millpond
Make the track short enough and you can go a lot slower--remember those motorcycles in a cage at the fair?
Old Feb 25, 2006 | 09:20 AM
serendipity's Avatar
serendipity
Not quite If it's sideways, there's no force pulling the car to the concrete. In a flat turn, you've still got 1g of force pulling the car and the concrete together, which is how it generates friction.
Old Feb 25, 2006 | 10:27 AM
ronsc1985's Avatar
ronsc1985
I have no idea whether the g-meter in the Corvette has multiple axis accelerometers or not. If it does then the effects of not being on level ground should already be factored out. If it doesn't then worrying about the accuracy is a waste of time since the meter is about useless for any percise measurements since there are few places on the roads that are perfectly flat. Even drag strips usually go up or down some and they all have a slight crown (less than the public roads) to help drainage.
Old Feb 25, 2006 | 11:29 AM
Black04Vert
The Vette only has yaw and lateral accelerometers and that's really all it needs. Yaw shouldn't be affected by orientation and the lateral G meter shouldn't factor out the level of the ground as the lateral component of gravitys acceleration should always be considered in addition to the cars lateral acceleration.
Old Feb 25, 2006 | 11:31 AM
leaftye's Avatar
leaftye
I'd expect the g-meter to be pretty accurate since the technology is very mature. During the Cold War, and before GPS, spy planes used to navigate solely by g-meters, and they did very well from what I've heard.
Old Feb 25, 2006 | 11:53 AM
C6 DVL's Avatar
C6 DVL
St. Jude Donor '08
how do you do that?
Old Feb 25, 2006 | 12:16 PM
C-INRED's Avatar
C-INRED
St. Jude Donor '06
I think you just turn the heads up to a mode with the g's displayed. It 'saves' the highest 'g' obtained for some period of time, I believe.
Old Feb 25, 2006 | 12:51 PM
C6-er's Avatar
C6-er
Originally Posted by C6 DVL
how do you do that?
While in one of the track modes just push and hold the page button for 5 seconds and it will recall the highest reading since power up. You don’t even have to be in track mode in the corner.
To G Meter accuracy??
Old Feb 25, 2006 | 01:07 PM
C6 DVL's Avatar
C6 DVL
St. Jude Donor '08
Old Feb 25, 2006 | 04:48 PM
ronsc1985's Avatar
ronsc1985
In general that is not true. To get accurate information which doesn't include body roll and front to back or back to front squat you really need a three axis system.
As an example if you have a drag car that wheel stands a simple lateral accelerometer would read much higher forward acceleration then the car was actually making down the track. Same thing is true for body roll.
This may all be a little picky but the original question was how accurate the G- meter was.
Old Feb 25, 2006 | 05:09 PM
xs650's Avatar
xs650
It would take more body roll than you will get in a C6 to cause a 1% error. Steeply banked corners are a bit more of a problem.
