XM Problem
Old Feb 24, 2006 | 06:21 PM
tex929rrr's Avatar
tex929rrr
Default XM Problem
Guys, I searched for this problem in the archives and FAQ's, and haven't seen it. Yesterday I drove to work listening to XM, as usual, with everything normal. After work I got "no signal" on every channel I tried. Note - I didn't get sound, even on channel one, which usually works as long as you are hooked up. I tried restarting the car and even disconnecting the battery for a while just in case it was a gremlin. I also made sure the receiver was still activated with XM. I figure this means a trip to the dealer, but I'm just taking a chance someone else has had this problem. I suspect an antenna problem. BTW, it's a 2005 1SB coupe.
Old Feb 24, 2006 | 06:25 PM
blkvc6's Avatar
blkvc6
wow-- My XM stopped working too-- But i discovered my trial subscription ran out!! kiss system works sometimes!!
Old Feb 24, 2006 | 06:37 PM
jersey shore c7's Avatar
jersey shore c7
i had the same thing happen took it to dealer it was xm module was bad
To XM Problem
