need help
Old Feb 26, 2006 | 08:02 PM
azvetters's Avatar
azvetters
Default need help
after 10 months my first errer"chech gas cap"
can you Access & read the codes,Diagnastic Display mode???
like you can on the C 5
ThankZ
Old Feb 26, 2006 | 08:12 PM
speedwaylemans's Avatar
speedwaylemans
ThankZ
I would imagine all it is is that last time you got gas the cap was not tightened properly. Take it off, put it back on and go thru several clicks to tighten. I bet that clears the code. Good luck
Old Feb 26, 2006 | 08:16 PM
Another Yellow's Avatar
Another Yellow
St. Jude '03-'04-'05-'06
Sorry, you can't access the codes on the C6 as you could on the C5.
Old Feb 27, 2006 | 08:59 AM
azvetters's Avatar
azvetters
did not work, did that first.cleared with reset button, but it returns everytime, thankz
Old Feb 27, 2006 | 09:12 AM
holdin5aces's Avatar
holdin5aces
Default and the manual says...
It may take several trips to clear this message after correctly installing the gas cap. Had the same thing after buying gas, removed and replaced the gas cap, but it was two days later till gone.
Old Feb 28, 2006 | 03:05 PM
azvetters's Avatar
azvetters
After more then a week of "check gas cap"at every start up.
Monday I went to the dealer,They scanned for codes No codes.
did a Evap Test "System Cap seal failed" smoke test,Leaking~
replaced Cap....
love this forum,thank's
Old Feb 28, 2006 | 03:12 PM
C8-Vette's Avatar
C8-Vette
Go to Walmart, buy the Innnova model 3030 OBD11 code reader for $69. It's CAN ready and you will be able to read and erase all codes on the C6 and any car made after 1996.
To need help
