Matching Transmitter(s) to
Your Vehicle
Each keyless access transmitter is coded to allow only
transmitters programmed to your vehicle, to work. If
a transmitter is lost or stolen, a replacement can
be purchased and programmed through your GM dealer.
Your GM dealer can reprogram your vehicle so lost or
stolen transmitters no longer work with your vehicle.
Each vehicle can have a maximum of four transmitters
matched to it.
To match a new transmitter to your vehicle when
you have a recognized transmitter (two recognized
transmitters are required for Canadian owners),
do the following:
1. The vehicle must be off.
2. Have the recognized and new, unrecognized
transmitters on your person.
3. Go to the rear of the vehicle and insert the vehicle
key into the key cylinder located above the license
plate. See Hatch/Trunk on page 2-14 for more
information on the key cylinder.
4. Open the trunk.
5. Turn the key five times within five seconds.
6. The DIC will display READY FOR FOB #X, where
X can be 2, 3 or 4.
7. Place the new, unrecognized transmitter in the
glove box transmitter pocket with the buttons
facing towards the passenger’s side.
8. Once the transmitter is programmed, a beep will
sound. The DIC will display READY FOR #X,
where X can be 3 or 4, or MAX # FOBS LEARNED.
9. Press the ACC button (ignition switch).
Your Vehicle
matched to it.
do the following:
4. Open the trunk.
X can be 2, 3 or 4.
DOH!!! I knew that book in the glove box would come in handy one of these days...I'm a dip, thanks for the help!!! :o :o :o
.................Info>> my wife lost both transmitters in a week to her GrandAm ............. Went to the Pontiac dealer was charged 100 bucks for just for programing the new transmitters , Cant recall price of transmitters think it was 42 bucks each ....& got the car back in 20 minutes & this included the washing & interior being vacumed.so it didnt take long to program , ( Approx $190 ,w sales tax) would have been better to take that car to Circuit city & have a remote start w 2 transmitters installed.for less $$$ to late now...... I think a quality locksmith can do the job & you probably, negotiate a better price....................
I tried this earlier with a "blank" fog, but it didn't work - I never saw any feedback from the DIC to proceed.
Well, turns out I wasn't turning the manual-key far enough. The amount to unlock the trunk manually isn't much of a turn. The degree of turning to program a new fob is quite a bit more.
Took less than a minute altogether... once I realized the above.
I too initially had problems programming a new 3rd FOB. But after letting it sit around for a few weeks I finally tried it again. Sure enough it worked. Seems the "turn the key five times in five seconds" was my problem. The last time I did it I really "turned" the key as fast and as completely as I could and bingo the DIC turned on.
As far as programing a FOB purchased off eBay I don't have a clue if the car will over write an existing program. Was it brand new???
My understanding is that you are actually training the car, not the fob. In other words, the fob code is individual and unchangable, what you do is train the car to "recognize" and accept that fob. If true, then a used fob should be accepted without problem because the car would not know if the fob had previously been used.
True, and with that in mind you should be able to program one FOB to work with more than one car. It would be nice to only have on "key" for the whole fleet. I only have one C6 so I can't test this...
I bought an FOB #2 from ebay and programmed it usign the method in the manual. However, when I try to start the car it says no FOB. I tried reprogranmming but the car already knows the FOB and I cannot program it again. Any ideas on how to make this one work?
