Wind Deflector Installation Help Needed!!
Old Mar 4, 2006 | 02:05 PM
cortnjeff's Avatar
cortnjeff
Default Wind Deflector Installation Help Needed!!
I have finished installing most of the wind deflector except I cannot find the wire harness that I need to connect to! Please Help!
Old Mar 4, 2006 | 06:05 PM
cortnjeff's Avatar
cortnjeff
Nevermind.... I found the wire harness. You have to follow the wire from the partition switch down under the carpet going slightly into the trunk. Overall, it was a pretty easy installation.
Old Mar 4, 2006 | 06:22 PM
2vettes's Avatar
2vettes
Pics? What kind of wind deflector uses a wire harness?
Old Mar 4, 2006 | 06:42 PM
cortnjeff's Avatar
cortnjeff
I still have to sign up somewhere before I can post pics. The wind deflector bracket that gets installed, for the power convertible top, has a wire harness that connects to the partition switch in the trunk. Since you have to remove the wind deflector before raising the top, it is a safety feature so no damage can accidently occur.
Old Mar 5, 2006 | 10:03 AM
2vettes's Avatar
2vettes
Thanks for the explanation.
To Wind Deflector Installation Help Needed!!
