I have noticed that when I raise the top, the angled manual latch leaves an indention on the foam on the backside of the tonneau cover. This is when I leave the latch in the unlocked position. If I replace the latch into the closed position before lowering the top all the way it is fine, but when I raise the top, it makes a thud where the lock part is protruding as is comes down to where it meets the windshield?? The owners manual does not comment on whether to leave the latch in closed or open position when raising/lowering. Anyone experience/notice this??? Is the indention on the foam normal, also I notice a little scrape on the tonneau cover itself. What should I do??
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Thats what the foam is there for. It makes no difference. If you'd like to close the latch upon lowering the top that's fine too, but when raising it, just take your finger off the button for a sec as it gets close to the end, open the latch, and continue the cycle.
I always close the latch when opening. There is just enough of a delay that at one point I close the latch and it doesn't skip a beat. The same thing when the top is going up. Just reach up and undo the latch. It's been working real good for me. If you have trouble then just let your finger off the button and the top stops. Then hold the button and finish.
