Electrical weirdness
Old Mar 9, 2006 | 08:44 AM
Velocity Jonny's Avatar
Velocity Jonny
Default Electrical weirdness
I've had my car since October 1st, without any problems whatsoever. I have about 3700 miles on her, and have basically been the only driver. Now my buddy from Idaho visits, takes the car out for about a 3 mile spin, comes back, and the map lights are on.
They will not switch off, no matter what. I start the car select through the gears, shut it off, I play with the accessory setting, etc. They are on. Period.
So finally, I disconnect the positive battery cable, and of course, they go off. And when I replace the cable, they are mercifully off. It's like I had to do a Control + Alt + Delete on the whole electrical system.
Now my pal says he didn't do anything during his 3 mile cruise, but I noticed that the "passenger door ajar" warning came up when I first started the car. Could it be that the map lights came on because the door was ajar, and then lost their mind?
The whole thing has me a little spooked, because previous to this, I have had absolutely no problem whatsoever. So it's a big surprise that the car's "brain" can freak like that.
Any ideas? Thanks in advance.
Old Mar 9, 2006 | 08:49 AM
prs62's Avatar
prs62
St. Jude Donor '05-'07
Two ways to turn the map lights on/off:
1. Press the map light in/out, or
2. Press the dimmer switch in/out.
Old Mar 9, 2006 | 08:50 AM
jnx911's Avatar
jnx911
Who knows what happened. Just keep an eye on it and if it happens again, take it to the dealer and let them figure it out. I have never heard of anything like this.
Old Mar 9, 2006 | 08:51 AM
Realtor Dan's Avatar
Realtor Dan
ahh hit it whith his knee...the dimmer
Old Mar 9, 2006 | 09:05 AM
babaganoosh's Avatar
babaganoosh
After 3 weeks I still cant figure out those dopey map lites. When I cant get them to shut off I ask my son to do it. Somehow he managed to figure this out.
Old Mar 9, 2006 | 09:14 AM
Vette_DD's Avatar
Vette_DD
Be sure all the doors are tightly closed. Be sure the map light buttons are in the "in" position. Press and release the dash dimmer switch.
Old Mar 9, 2006 | 09:59 AM
dacampi1's Avatar
dacampi1
Old Mar 9, 2006 | 10:07 AM
scrannel's Avatar
scrannel
First time I did it, drove me nuts.
Old Mar 9, 2006 | 11:02 AM
noreserve's Avatar
noreserve
This happened to me as well. Probably has happened to many. I'm outside the car and notice that the interior map lights are still on. I waited for them to go off, thinking that there was a delay. It was obvious after a couple of minutes that they were going to stay on. It took me probably ten minutes to figure that the $^%#@ dash dimmer light controls the interior lights by pushing it. Also, it's not intuitive to me that the map lights push in to turn them off. It's usually the opposite. I think they missed the boat on that one.
Old Mar 9, 2006 | 11:25 AM
thom_s's Avatar
thom_s
You should only drive the car. Not others !
Old May 21, 2010 | 10:57 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
I just noticed the opposite! My maps won't come on? Door open/closed, switch on the mirror, switch on the dash? Nodda? The only thing I can guess as a possibility is I've installed LEDs in the footwells? They come on with any of the above actions, but no maplights. Everything else in the mirror works fine, as do the courtesy lights (footwells), but no maps? Is it possible that the LEDs don't draw enough to activate the maps? Any help? (Worse things could happen, but I miss the little buggers).
Old May 21, 2010 | 11:15 PM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
http://forums.corvetteforum.com/foru...s-or-more.html
To Electrical weirdness
