Run flat means,...?
Old Mar 9, 2006 | 04:27 PM
water boy's Avatar
water boy
Default Run flat means,...?
What exactally does run flat mean.
I keep reading about posts and threads where owners are getting fllats. I thought that run flat meant that the tire would not go all the way flat?
thanks
WB
Old Mar 9, 2006 | 04:29 PM
Vette_DD's Avatar
Vette_DD
It means that if the tire goes completely flat, 0 psi, you can still drive the car at speeds of 55 mph or less for 100 miles.
Old Mar 9, 2006 | 05:10 PM
pls's Avatar
pls
You need them since there is no spare tire in the car. Get ready to spend 380-420 each to replace.
Old Mar 9, 2006 | 05:16 PM
PaBlueCoupe's Avatar
PaBlueCoupe
St. Jude Donor '06-'07-'09
Old Mar 9, 2006 | 05:29 PM
water boy's Avatar
water boy
The cost of enjoyment.
What kind of mileage have these been getting, hopefully more than the Z51s.
thanks
WB
I am refering to the base C6 tires here.
Old Mar 9, 2006 | 06:18 PM
Vette_DD's Avatar
Vette_DD
I bought a gauge to check the treadwear on my C6. Looks like I'll probably get 28K to 32K on my non-Z51 05 C6. The right front tire I had to have replaced after hitting a road hazard was $303 without balancing & mounting.
Old Mar 9, 2006 | 06:23 PM
BKNIMKR's Avatar
BKNIMKR
From: Chino Hills, Ca. You are completely safe with me, I'm a good screamer.
Went down to zero pressure two weeks ago. The tire operated perfectly! I drove about 10 miles at speeds up to about 45mph, as I headed to a GY tire center. No damage to the wheel. It was weird to press firmly on the sidewall and have plenty of resistance, yet when I pressed on the tread area, it would cave in!
martin
Old Mar 9, 2006 | 08:49 PM
water boy's Avatar
water boy
Driving on a flat is def. cool.
Thanks for the info.
WB
Old Mar 9, 2006 | 09:02 PM
FunDriver's Avatar
FunDriver
Veteran: Marine Corps
I had two flats on my C5 and on one of them I finished going to dinner that night, went home, got up the next morning and after breakfast went to the tire shop and got it fixed. Definitely cool.
The only problem I had was when the DIC started dinging and said that I had low tire pressure, I quickly maneuverd in traffic to get to the side of the road...and then remembered that I had runflats and didn't have to do anything. So I just took off again and continued on my way.
To Run flat means,...?
