Question re: test drive
My question is: Is this normal, or was she a bit loose due to cold tires? cold road surface? Z 51? Will this happen during normal summer driving?
Thanks for any input
Z51 IMO:
sway bars.....improvement and a nice mod to a non Z51 car
brakes....modest improvement skip them and upgrade to Z06 brakes
coolers....who needs em?
shocks...they say the ride is either to rough or much better your choice
manual trans gears....big deal
tires....might get you killed if it's cold
engine.....here's the good part.....absolutely identical to every other C6 except the Z06
Best case IMO is to upgrade non Z51 car to Z51 sway bars and Z06 brakes
just my opinions your results may vary.....
I live in the area here and at this time of year there is still residue on the streets that make traction a little less than ideal.
You mentioned you hit the gas.........First of all, I don't understand what you mean by a slight pause, this car is immediately responsive, not like a turbo..............These cars are very powerful with a lot of low end torque.
If you have your wheels at a 45 degree angle through your turn and you hit the gas (not to mention in colder weather), yes the back end will slip. Driving this car requires a patient right foot. There are many cars where you can just mash the pedal because they can only take what you can dish out. This car offers more and you need to learn it's limits.
I recommend you take the car back out on a clear day and try this:
1) If you want to see the power, hit the gas when the front wheels are pointed straight.
2) take turns modestly and increase throttle as you get more familiar with it. Apply the gas throughout the entire turn squeezing it accordingly.
3) The rear end is very manageable when it swings out, the problem is most people give up on the maneuver because it usually requires a bit more sliding to bring it back in line then they are comfortable with. Negotiating turns in the city may not allow you this room so you have to use some common sense.
Warm weather will bring these problems to a halt.
Mike
His Z51 envy is apparent in virtually every post he makes. And it is quite amusing watching him attempt to justify his own purchase and convince himself that he made the right move by passing on the Z51 performance package.
Heres my all time favorite:
So 1.5 seconds is 15 tenths. This means that if the base C6 with manual trans is X then the manual Z51 is X+1 and the Z06 is X+15. This is not a linear plot. Neither the Z51 or the non Z51 is anywhere close to the Z06 and , in fact, they are almost identical to each other.
http://forums.corvetteforum.com/show...43&forum_id=74
Other tidbits of wisdom from OregonC6
"Of course, there is the status appeal of the car and I suspect that will be the primary reason most people allow themselves to be robbed blind by the dealers with add on markup above msrp. just my opinions".
Just something that those who want the best factory performance capabilities available in the C6 without going to the Z06, should get.
And for the type of racing for which the Z51 was built, and with a capable driver, a fellow forum member was good enough to post this thread and video. Off the mark huh? :
So don't stop him now. He's on a roll.
The car was working as designed. You lived to tell the story and not a scratch on the car.
Tom
SO,all in all it's pretty normal for Z51!!
