Computer memory saver actual experience
Old Mar 21, 2006 | 02:03 PM
Gary Chesnut's Avatar
Gary Chesnut
7th Gear
Default Computer memory saver actual experience
Need recommendation for a computer memory saver to use when battery is disconnected on the newer computerized Corvettes.
Old Mar 21, 2006 | 02:10 PM
VET4LES's Avatar
VET4LES
Radio Shack might have them. They are a 9 volt battery that plugs into the lighter if it is non switched.
Old Mar 21, 2006 | 03:58 PM
Hoonose's Avatar
Hoonose
For what ever reason, most things in memory get saved on the C6 despite loss of battery voltage.
The windows need to be re-indexed, but I think that's about it.
Old Mar 21, 2006 | 04:29 PM
GMD's Avatar
GMD
Getting it "on" is the difficult part, but there is a thing called a "green ****" that I've used in the past when I was doing computer tuning on another vehicle. Basically, it installs between the post and the cable and to disconnect the battery you just unscrew the ****. They have a "plain" model and one that has a fuse and a low power circuit that won't permit the car to be started, but puts enough voltage on it to maintain your radio and computer presets.
I hesitate to post a link to a none forum vendor but if you do a web search for "green ****" on google, you'll find at least one vendor in the top 5. I don't think any forum vendors have them, but I may be wrong, you might want to check with them, first.
To Computer memory saver actual experience
