Antilock brake question
Just go out and do some practice braking and literally SLAM on the brakes, making sure your not touching the throttle. Don't worry, you won't break the brake pedal. Got to fully engage it!
It wasn't even close. I stopped a good three car lengths short of impact. Then I started listening for the screeching brakes behind me, but luckily the cars behind me weren't watching the same girl.
Bottom line--the brakes work great in this car. My dentures are still rolling around up front by the defroster somewhere.
Sweep and Smoke--Jimbo
If you kept moving forward you either didn't shove in the clutch far enough, you weren't "standing on the brakes" or you were riding on a grease spot.
You're correct, the ability to steer IS the POINT of ABS.
It's hard not to be hitting the brakes with gusto when you are bearing down on the rearend of a Silverado 2500 quadcab. If I'm not pushing the brakes in far enough, I need to understand why.
As for the clutch being all the way in, the motor was still running as I sat there after alleviating the rear tires of the truck of their burden of holding up the rearend.
I was just wondering if others had experienced this phenomena or not. My son suggested that maybe by hitting the gas and brake together the computer thinks I am doing a "heel and toe" manoeuver instead of emergency braking. A mechanic has suggested that maybe the computer gets confused when both the gas and brake are pressed at the same time.
Maybe a change in driving position will be enough to stop the problem of hitting both at the same time in an emergency.
Maybe I just need narrower shoes.
But if like you said - your car didn't have any steering control whatsoever- then yeah, that is weird.
...You weren't held at fault for the accident were you? If so it's time to move to a county/state where the local law enforcement has an average IQ over 3
I was thinking the active handling might have kicked in forcing the car to maintain forward stability as opposed to allowing the back end to slide beyond a predetermined programmed setting. This is the only explanation I can think of. The ABS helped slow the vehicle, but I had very little directional control.
Sorry…did not mean to hijack this thread. I was going to post an ABS question and then saw this thread and posted my own experience.
It DOES feel exactly like the ABS on 99 Eldorado, and on my daughter's Saturn - so I think you're correct in feeling you would have felt the ABS engage. (Actually, I've noticed it engages very easily, and I've assumed this is due to the massive front rotors.)
I think if you didn't feel it through the sole of your shoe, it didn't happen - and it sure sounds like it should have. Pretty scary - malfunctioning ABS.
