Caliper Paint
Old Mar 25, 2006 | 11:47 PM
talldude67's Avatar
talldude67
Default Caliper Paint
A while back there was a thread on painting your CALIPERS with a brush, comes to mind the paint brand I think was ONE-SHOT, not sure tho [very small can] anyone still have that thread or info on brand purchase's. Looked in FAQ but didn't find an answer...Thanks: Save the Wave >>>
Old Mar 25, 2006 | 11:53 PM
TommyV's Avatar
TommyV
St. Jude Donor '06-'07-'08-'09-'10-'11-'12, '16
Dupli-Color makes some.
Old Mar 26, 2006 | 12:11 AM
FourFather's Avatar
FourFather
St. Jude Donor '08 thru '17,'22
Default I did mine with a brush-
Without taking them off. Used a spray can of (engine?, I think) paint, sprayed some in the cap, to use as a paint bucket, and brushed it on. Not show quality, probably, but OK for me.
Good luck!
Eddie
Old Mar 26, 2006 | 06:41 AM
BigJag's Avatar
BigJag
Dupli-color has a caliper kit out that comes with the paint, a solvent to clean the calipers, and a brush. I just did mine last weekend. Turned out great (IMO) but its kindof a pain to do. Just takes several hours, at least it did me. Between jacking up the car, taking off the wheels (great chance to clean them), taking off the brake pads (optional, you can do it with the pads on just easier with them off), and the paint doesn't cover that well so I put a few coats on. Probably had 10-12 hours invested in the job.
Old Mar 26, 2006 | 07:03 AM
Gillvette's Avatar
Gillvette
Thats what I used.....they came out great!
Old Mar 26, 2006 | 08:09 AM
RBYCC's Avatar
RBYCC
Try Rustoleum Industrial Alkyd (oil base) Enamel, comes in the "OSHA Safety" colors. Cost about $7.00 quart, can be found at Lowes. I used safety red, goes on easy, good coverage, fast dry to tack, can do a wheel in about a half hour or less. Dries to a high gloss and shows no brush marks.
Old Mar 26, 2006 | 08:25 AM
jschindler's Avatar
jschindler
I've used Rustoleum on three Corvettes. No, not any High Temp or Barbeque paint - just the regular Rustoleum. It works fine and there are a lot of colors to choose from.
Old Mar 26, 2006 | 08:46 AM
RBYCC's Avatar
RBYCC
As long as it's the "alkyd enamel", not the "latex".
Rustoleum was great in building race engines. After machining and washing down the heads and block with "Tide", you'd paint all interior non machined surfaces with a high gloss Rustoleum. This would do two things, seal in any possible metal fragments left over from machining and give a slick non porous surface that allows oil to flow back to the pan much faster. "Alkyd enamel" good for over 500 degrees F. and is very chemical resistant
Old Mar 26, 2006 | 09:14 AM
Illinicane's Avatar
Illinicane
St. Jude Donor '06
Corvette Pilot has a powercoated system. they look awesome.
Old Mar 26, 2006 | 01:05 PM
talldude67's Avatar
talldude67
Default thank you
TO ALL MEMBERS FOR THE INPUT AND YOUR QUICK RESPONCE.....
To Caliper Paint
