Window Tinting
Old Mar 26, 2006 | 01:43 PM
AFRET's Avatar
AFRET
Default Window Tinting
I have finally decided to tint my car, but I am a little concerned about the issue of the back window. I would love to have one-piece install in the rear window. Does anyone know of a good window tinting company in the Tampa/Brandon area?
Old Mar 26, 2006 | 06:34 PM
BLWright's Avatar
BLWright
If the tinter has never done one, make sure he shrinks from the rear forward. It will not shrink right if he starts at the halo.
Old Mar 28, 2006 | 05:07 PM
Deftly's Avatar
Deftly
Another thing I found out is it is hard to get the tint material to lay flat at the top of the rear window of the coupe. The window is full of little dots. My tint looks like crap up in that area. Installer warned me that he couldn't do anything about it.
Old Mar 28, 2006 | 05:45 PM
Fore58's Avatar
Fore58
If you have the Navigation System, which do you use the ceramic or metallic tint? I've heard that tint could cause distortion.
Old Mar 28, 2006 | 05:51 PM
BLWright's Avatar
BLWright
if he'd used steel wool and some 70% alcohol, you wouldn't have that problem. you can even shave the dots down with a razor blade too if you have the time. but steel wool works fine.
Old Mar 28, 2006 | 06:07 PM
Daytona Sunset 2k5's Avatar
Daytona Sunset 2k5
St. Jude Donor '07
my coupe looks fine and it was a single piece of tinting material...but im in socal, so sorry, cant help ya with a shop
Old Mar 29, 2006 | 08:38 AM
Deftly's Avatar
Deftly
What's the purpose of the dots - shade?
Old Mar 29, 2006 | 10:37 AM
djgcue's Avatar
djgcue
Try using black vinyl on the dot matrix areas.
Old Mar 29, 2006 | 10:53 AM
BigJoe's Avatar
BigJoe
Your installer should have told you to take a sponge or towel and press the film into the dots during the first week as it dries. If you do that the film will bend itself around the dots a bit and become much nicer looking. You have to do it once or twice a day for the first week or so, working from the lower dots out to the edge of the window. It takes a lot of pressure to do it right, so don't be gentle...
Old Mar 29, 2006 | 04:24 PM
Deftly's Avatar
Deftly
He said nothing. Is the sponge/towel wet when you do this? Or is the tint material still wet? It has been a week tomorrow - hope it's not too late.
Old Mar 29, 2006 | 04:39 PM
ttlpakg's Avatar
ttlpakg
Dont mean to crash your thread.
But I attended the last OC C6 gtg and I saw a lot of good tint jobs. Where is a good reputable tint shop in SoCal that I can go to???? Advise. Thanks
Old Mar 29, 2006 | 05:16 PM
BigJoe's Avatar
BigJoe
I used a dry microfiber towel. Just press the film into the dots. Helps if the film is hot, like in the sun for a few hours. It doesn't come out perfect but better than doing nothing. Here a part of mine:
Old Mar 29, 2006 | 05:27 PM
Cavallo GT's Avatar
Cavallo GT
St. Jude Donor '07
Please let me know how you make out with this. I'm in Tampa and want to get mine done asap. A lot of heat comes in through the side windows! Thanks.
To Window Tinting
