C6 fuel
Old Mar 27, 2006 | 01:11 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
If using low octane fuel, you are depending on the knock sensors and timing retard to protect your engine from destruction. That's not the way i want to do things.
There are enough other things that can go wrong, don't add another one to the list.
Old Mar 27, 2006 | 01:29 PM
double eagle's Avatar
double eagle
Originally Posted by fts
I never go under 93 octane.
- my baby deserves the best stuff to drink
Old Mar 27, 2006 | 03:03 PM
Purdue's Avatar
Purdue
In Phoenix, Arizona the best that you can get from stations is 91 Octane! I remember living in the Midwest and all gas stations appeared to carry 93 Octane.
Old Mar 27, 2006 | 05:28 PM
LDB's Avatar
LDB
Originally Posted by Hoonose
Somewhere in the manual it states for C6 to use 93 octane for maximum performance. I don't have access to a manual now...
I don't remember seeing that other than for Z06 which I mentioned in my earlier response. But if it's there, I could think of three possible explanations. The least likely is that under normal circumstances, you'd benefit because the car is really tuned for 93. If that were the case, it's hard for me to understand why the manual wouldn't just say 93, rather than say 91 with some obscure buried footnote about 93.
The next possibility is to cover themselves against use of cheap gas. What gets posted is (R+M)/2 octane, but most cars are more sensitive to M than to R number. It is cheaper to make R number in a refinery than M number. So one of the dirty little tricks that a disreputable refiner can use is make 91 by, for example, 98R+84M, rather than the reputable way of 96R+86M. If you have a bit of extra R+M, it is more difficult to get M below 86.
The last possibility is to cover yourself against an aging engine. As the engine ages, deposits and other irregularities will increase octane requirement by a number or two. So by the time you get our to 75,000 to 100,000 miles, your car that started out needing 91 can actualy be up to needing 93.
Old Mar 27, 2006 | 05:45 PM
humvet's Avatar
humvet
While owning my C-5, I went long periods of time using 87 octane and could not tell the difference from the 91+ octane. The only vehicles where higher octane was relevant for me was for the VW busses when driving over mountains. The higher octane eliminated knocking.
My rule is and always will be, if you feel the difference, use the higher octane. I challenge the CF gang to have someone pump the gas for each of you a couple of times without telling you what the octane level is. If you do a true blind study like this, I believe you will come to the same conclusion as I - higher octane is a psychological booster, not a performance booster. Save the bucks and spend them on C6 mods!
Old Mar 27, 2006 | 05:52 PM
dbradley's Avatar
dbradley
I read the other day that CA was looking at 89 being the top grade. It is written in some new emissions bill floating around at State level.
Old Mar 27, 2006 | 05:57 PM
own2vettes's Avatar
own2vettes
My wife drove my car this weekend and put gas in it. I suspect that she used 87 octane because when I would accelerate, the engine would make noise. It sounded like noisy valvetrain chatter. The car seemed to accelerate okay but this dang noise was driving me crazy!!! I checked everything underhood and all seemed intact. I suspected the bad gas because she's done it before. I filled up with premium 93 octane and also added a bottle of octane boost and, voila, the noise is gone. 87 octane may be ok for regular engines, but 93 is what high compression engines need. you run the risk of knocking if you use the low octane stuff. Use the high octane. Your car will thank you for it.
Old Mar 27, 2006 | 05:59 PM
EuroRod's Avatar
EuroRod
A friend of mine has an identical Hemi Ram truck as mine (except color), down to the bed rails and fender lip chrome. I use 87 regular. He uses 93 preminum. My truck will pull him about half a car in the quarter. I have never had a minutes trouble from this truck. Told him the money I save in fuel helped pay for the Vette. But I do use 93 preminum in the Vette.
Old Mar 27, 2006 | 06:24 PM
joela's Avatar
joela
Originally Posted by tak
In the engine mapping there are two sets of adjustments for the car to run on. One is with lower timing.
Logic says that if you use lower grade fuel it will use the lower performance set, and thus your engine will be safe. You will not have the 400 bhp and 400 lb/ft torque though.
This was seen using the LS2 edit
if your c6 is running on the lower octan table, you will lose 10-20hp or more depends on how big of a knock it is.
Old Mar 27, 2006 | 07:20 PM
Hoonose's Avatar
Hoonose
I see 91 in the manual, but 93 on the Chevy website listing LS2 specifications.
Old Mar 27, 2006 | 07:22 PM
Hoonose's Avatar
Hoonose
There have been posts suggesting that too high an octane will lower HP. Just what is the octane recommendation for your hemi?
Old Mar 27, 2006 | 07:32 PM
EuroRod's Avatar
EuroRod
Think the owners manual simply states 'premium fuel recommended'. Too lazy to go look.
Old Mar 27, 2006 | 07:40 PM
  #33
sherriff's Avatar
sherriff
Default C6 Fuel
Thanks guys, PREMIUM it will be (even though in Canada the price difference from 87 to 93 is more like 50 cents a gallon.
Old Mar 27, 2006 | 10:00 PM
  #34
SDCEB's Avatar
SDCEB
I would only use premium, unless it wasn't available.
Old Mar 27, 2006 | 10:04 PM
  #35
dennis50nj's Avatar
dennis50nj
sunoco 94 in new jersey much faster
Old Mar 27, 2006 | 10:09 PM
  #36
mnmvette's Avatar
mnmvette
Originally Posted by ShockwaveTXB
Regular is "acceptable" because it's the law.
The car was designed to run on Premium, the fact that you can run it on regular is a requirement by law, but not what's meant for optimal performance.
Also, do you buy a Corvette so that your experience is only "satisfactory?"
Old Mar 27, 2006 | 10:13 PM
  #37
2005ArcticWhite's Avatar
2005ArcticWhite
St. Jude Donor '05 thru '11,'18,'20,'21,'24,'25, '26
Old Mar 27, 2006 | 10:43 PM
  #38
LS WON's Avatar
LS WON
Here in California it is either Chevron or Union 76 for me. Don't care for Shell gas.
