Z51 better than Z06!! Lasts longer
![](/forums/images/ranks/5k-6k.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Ok Now I know why I have a Z51. My friend has a Z06 & just at 1700 mi. Broke the rear right axle!!
He is now known as #7 in the Z06 site & at Bowling Green ,as that is how many have broken so far!! WOW ,did GM make tham TOO light weight?
![EEK!](https://www.corvetteforum.com/forums/images/smilies/eek6.gif)
![No No](https://www.corvetteforum.com/forums/images/smilies/nono.gif)
![](/forums/images/ranks/4k-5k.gif)
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05
![](https://www.corvetteforum.com/forums/images/ranks/cf10.jpg)
Hopefully they won't void his warranty by claiming that he abused his car.
![](/forums/images/ranks/7k-10k.gif)
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
He is now known as #7 in the Z06 site & at Bowling Green ,as that is how many have broken so far!! WOW ,did GM make tham TOO light weight? ![No No](https://www.corvetteforum.com/forums/images/smilies/nono.gif)
The Vette gods are going to get you next!
Originally Posted by ZeusC6
Oh boy, you've done it now!
![Big Grin](https://www.corvetteforum.com/forums/images/smilies/biggrin5.gif)
![Leaving](https://www.corvetteforum.com/forums/images/smilies/leaving.gif)
Get Some!
![](https://www.corvetteforum.com/forums/images/ranks/veteran_army.png)
http://forums.corvetteforum.com/show...3&forum_id=100
1/ The Z51 option is a great value.
2/ The Z51 option adds considerable performance to the base C6.
3/ People who order Z51 are very wise shoppers and really know their vettes. Z51 owners are justly proud. I admire Z51 owners.
However, please, please:
4/ Use of the phrase "better than" to describe any aspect of the Z51 in comparison to the Z06 is just absolute nonsense-and I do mean "any".
The model is in its' first year and is one of the most powerful cars ever produced for widespread sale. From all accounts it is unbelievable. When you build close to the edge things break. They will get it right.
( unless they all go on strike over Delphi !!!! )
all IMO and with kind regards to all Z51 owners everywhere...
( maybe your friend would agree with your assessment and would trade you even......it's worth asking him.....)
![](/forums/images/ranks/11k.gif)
CI-7-8-9-10 Veteran
Cruise-In IX AutoX Winner
St. Jude Donor '05-'06-'07-'08-'09-'10-'11,'19,'22
St. Jude/CI Name Tag Designer
Sounds like my Z51 in the quality dept.
![*****](https://www.corvetteforum.com/forums/images/smilies/willy_nilly.gif)
Originally Posted by OregonC6
Well, several things are certain IMO:
The above opinions are no doubt based upon sound fact, documented performance results, both past and present, reviews, and the fact that the Z51 equipped C6 is held in high esteem by many in the automotive journalism community. The C6 Z51 enjoys a very favorable and well earned reputation, among many in the automotive community, for its performance capabilities.
The C6 Z51 along with the C6 Z06 is in use at the Spring Mountain Motorsports Ranch, home of Spring Mountain Advanced Driving School. It was said by none other than Dave Hill himself that the C6 Z51 was very close in overall performance to the C5 Z06.
So yes, your opinion is consistent with that of many others who have had the great fortune to see this very special Corvette for what it is. Either through driving it, owning it, or both.
And thanks for the "kind regards."
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
Originally Posted by LS WON
It is more than likely owner abuse and hard driving like the track that contributes to the breakage as well as the people who service it.
I had 500 drag strip passes in two C5 Z06s with no breakage. My C6Z should be able to yield the same service. The "best" Corvette to date should be able to take a launch and strong shifts without breakage.
There is a design flaw in the C6Z CV joint housing that is causing the breakage. When it fractures, the metal pieces are severing the right rear brake line, clearly a safety issue that commands remediation.
Ranger
![](/forums/images/ranks/1k-2k.gif)
Originally Posted by Tavarez
If I were you i'd hit the trenches, the mortars are coming.
Guy's this could happen to ANY Corvette. You'll start seeing more and more of these reports as folks start taking their vette's to tracks all over the country and every once in a while a car is going to "hook up" for a second and BAM something's gonna break.
Plus we don't have all or ANY facts on this incident. If there is a "defect" that's different and I hope GM doesn't screw the owner. I hope this guy joins the CF and provides more details plus GM's response.
Tom
Tom
![ROFL](https://www.corvetteforum.com/forums/images/smilies/rofl.gif)
Tom
Tom
This incident is described in post#94, and it is quoted below.
Originally Posted by vipervetteguy
Just finished installing my LG headers and took the car out for a drive to listen for rattles, etc. Absolutely perfect and sounds great......and then I did a hard shift into 2nd. All sorts of bad noises and the engine hit the rev limiter. I pushed the clutch in and coasted to the side of the road. I picked up the pieces on the street and called Chevy for a tow. Looks like I won't be driving to Halltech tomorrow for a tune!!
FYI: Car was built on 12/21 and has 1700 miles on it. It was only 40 degrees outside, so the streets were cold. Stock tires, too.
Originally Posted by Ranger
Of the documented incidents (presumably more, yet unreported on the net)
• all occurred on the street
• all were on stock tires
• none had TM-edited-out
• only one was lowered
• most occurred on the 1-2 shift
Even more cars, including my own, show signs that the CV joint housing has impacted (and left paint scars on) the frame without yet breaking. That housing has 2.5-3 inches of clearance from the frame and should be safe...if the differential didn't displace upward.
Ranger
Ranger
![](/forums/images/ranks/3k-4k.gif)
Wow...some of you guys got some egos for sure....
Z51 is for girly men? LOL
The funny thing is you can have C6 Z06 power out of the LS2 with not much work at all. Whatever, that is a whole other topic.
![Lurk](https://www.corvetteforum.com/forums/images/smilies/lurk5.gif)
![](/forums/images/ranks/2k-3k.gif)
It's amazing how often sarcasm is mistaken for seriousness on this forum.
On topic- IMO, it sounds like GM certainly needs to give some attn to this issue, but it's still hard to say whether this is a production issue, an owner fault issue, or a combo of the two.
This car has amazing power/torque. Couple all of that power with light weight, and things can can wrong quickly if the car is not treated properly.
I have had zero issues thus far. (fingers crossed)
